Old 04-29-2008, 09:06 AM
mathew stouffer mathew stouffer is offline
Cracks in wall
Just curious what you would report about a small step crack in drywall. The crack ran from one corner of the wall, across the wall to the kitchen cabinets. It was about 1/16 of an inch and had one large step. It is very difficult to recognize in the photo. Major settlement issues with the driveway slab is why I ask.
Old 04-29-2008, 09:21 AM
Scott Patterson's Avatar
Re: Cracks in wall
You need to look at doors, windows, trim molding, etc., just one crack does not usually mean very much, but you need to take other signs into consideration.
Scott Patterson
Old 04-29-2008, 09:27 AM
Re: Cracks in wall
There was one other crack, however doors, windows were fine.
Old 05-10-2008, 10:24 PM
Justin Watts Justin Watts is offline
Re: Cracks in wall
I agree, check all the doors and windows, open and close them.... What kind of foundation is it? Any defects, upgrades needed, etc.? You need to evaluate the totality of defects...to make a better determination.
Also, don't forget the "soil" ....... You may want to advise your clients to get a soils report or geo-technical evaluation
Just make sure to let your client know that you are not a structural engineer, you do not do soils evaluations, etc. Cracks happen in surfaces, and all structures have some degree of movement that causes cracks.
Hope this helps,
Justin
Orange County Home Inspectors, Certified Home Inspector, property inspectors, Huntington Beach Home Inspection, Laguna Beach and Santa Margarita Home Inspection Services
Old 05-11-2008, 06:25 AM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Re: Cracks in wall
Looks like a failure of the top and edge seams on a sheet of drywall. What is the cause of the circular dark spot at the corner of the crack?
  #6 (permalink)
Old 05-11-2008, 06:44 AM
Lee Nettnin's Avatar
Lee Nettnin Lee Nettnin is online now
Re: Cracks in wall
Looking at Michael's enhanced photo, I was thinking that this could be an archway or doorway that was patched over and closed off. Were the same cracks present on the other side of the wall? or if it's an outside wall can you tell if the siding was patched?
Lee
www.eagleeyeinspectionshome.com
  #7 (permalink)
Old 05-11-2008, 07:12 AM
Richard Rushing's Avatar
Re: Cracks in wall
My top 10 to consider:
1) As stated, interior cracks above/ below windows and at the top corners of doors.
2) Flooring being uneven, cracked tiles, buckled wood planks, etc...
3) Exterior brick cracks from window corners (top/ bottom)
4) Exterior cracks where expansion joints are or should have been.
5) Fascia board corner trim separation
6) Ridge board-- separation of rafters
7) Hip jack rafters should be checked for separation
8) Fogged windows
9) Trees too close to the foundation-- evidence of roots causing upheaval
10) Improper grading and drainage (all encompasing of soils, guttering, high soils, low soils, dehydrated soils, areas of ponding water, etc...)
Richard
Richard Rushing, HCRI
Duncanville, Tx.
Similar Threads
Drywall Cracks MaMa Mount Building Interior: Home Inspection and Commercial Inspection 6 03-10-2008 01:04 PM
Single Wall vs. Double wall vent pipe Jonathan Clevenger Plumbing System: Home Inspection and Commercial Inspection 2 03-08-2008 10:10 AM
Cracks through bricks Clay White Structural Components: Home Inspection and Commercial Inspection 7 10-26-2007 06:46 PM
Cracks in flue Phillip Stojanik Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 22 07-18-2007 04:12 PM
wall/floor cracks Vince Santos Structural Components: Home Inspection and Commercial Inspection 2 05-07-2007 07:43 AM
vB.Sponsors
Ad Management by RedTyger
