Old 06-06-2008, 06:58 PM
Anthony Alderman's Avatar
Anthony Alderman Anthony Alderman is offline
floor joist... need help
All right guys I need some help. I was in this 1920's 2story yesterday. The owner had tried to fix the structural problems to sell it. You can see in the photos that the help she got didn't help. My question is this is there a minimum that a joist can be cut before being placed on a ledger strip. Even with a joist hanger? The photos can explain it better than I.
Tony
"A woman is only a woman, but a good cigar is a smoke".
Kipling
www.aahomeinspectionsllc.com
Old 06-06-2008, 07:05 PM
Steve Frederickson Steve Frederickson is offline
Re: floor joist... need help
The joists without the hangers are no good because the notching is excessive.
The joists with the hangers are no good because the hangers aren't the right ones for that depth joist and they are too low to use all of the nail holes in the flanges. The rot (termites?) in the beam is also a problem, and the brick pier looks deteriorated.
Old 06-06-2008, 07:10 PM
Tony,
The biggest mistake they made (and it defeats anything and everything else they did) was to *not* replace that beam/girder and try to add new wood to the sides of it.
If nailed or lag bolted to the old beam/girder, what are the nails going into? Decayed/termite damaged wood?
If they tried to through bolt from new wood to new wood, the old would in the center defeats much or most of the strength they were trying to add with the new wood. Those two new wood peices need substantial and stable support between them, and that old decayed/termite damaged wood will not provide that.
Hopefully, Brandon Chew will comment further (and, hopefully, not shoot my thinking full of holes ).
Old 06-06-2008, 07:26 PM
Ron Bibler Ron Bibler is online now
Tony all the above post are correct. If she is selling the home and is low on cash. sell the place as is and let the new owner deal with this condition.
If she has the cash. Then remove and replace the damage materials with correct construction. Contact a local termite inspector for a complete inspection report.
Best
Ron
Old 06-06-2008, 07:43 PM
Well it seem that my guts were telling me the right things. Thanks. I was inspecting for a buyer. They had been told the the floor system had been worked on and was now fixed. So thats what they wanted me to look at first. Thats as far as the inspection went, they pulled the plug.
Kipling
  #6 (permalink)
Old 06-07-2008, 09:05 AM
Jerry McCarthy's Avatar
Personally I fail to see any problems in those photos because that beefy brick pier is capable of supporting any load imposed and that kiln-dried original girder has little or no weight left in it.
Construction Consultant
Home inspection
Similar Threads
Rim Joist Question Sean Bacon Exterior Systems: Home Inspection and Commercial Inspection 9 03-01-2008 09:39 AM
Floor Joist? Clay White Structural Components: Home Inspection and Commercial Inspection 4 11-03-2007 06:37 PM
Joist span wayne soper Exterior Systems: Home Inspection and Commercial Inspection 2 05-18-2007 12:08 PM
Scissor joist Mike Schulz Sub-Structure: Home Inspection and Commercial Inspection 9 04-11-2007 08:41 PM
Joist support Francis Turak Structural Components: Home Inspection and Commercial Inspection 14 04-04-2007 06:15 PM
vB.Sponsors
Ad Management by RedTyger
