Old 06-11-2008, 03:44 PM
wayne soper's Avatar
sill plate
I always theough that a doubled 2x6 was required for a sill plate but I can't find the code in my book. Anyone have this? I did a home today with a single and it was all over the place so now I'm trying to find the Santa clause so to speak.
Old 06-11-2008, 04:16 PM
Ron Bibler Ron Bibler is offline
Re: sill plate
Is this for a 2 story ? Why 2X6 ?
In Calif 1 2x4 PT plate is code.
Best
Ron
Old 06-11-2008, 04:18 PM
Re: sill plate
Yes 2 story. 2x6 2x4 no matter. My concern is whether we need them stacked, doubled. One on top of the other. This house had one plate set on the top of the block.
Old 06-11-2008, 04:39 PM
Gunnar Alquist's Avatar
Re: sill plate
Quote:
I rarely see doubled mudsills. A single mudsill is standard, at least in my area.
What is the circumference of a moose?
Old 06-11-2008, 04:48 PM
Re: sill plate
Thanks Gun!
  #6 (permalink)
Old 06-11-2008, 08:04 PM
Re: sill plate
The only reason to double them is to spread the load to supports not aligned with the load above, such as with single and double top plates. Single top plates require the joists/trusses to be closely aligned with the studs below, a doubled top plate eliminates that alignment need - the joists/trusses can now land wherever they fall.
When place on concrete, there is no need to double it.
  #7 (permalink)
Old 06-11-2008, 10:35 PM
Brandon Whitmore Brandon Whitmore is offline
Re: sill plate
Or, to raise the floor system a little, etc.
  #8 (permalink)
Old 06-12-2008, 07:27 AM
Re: sill plate
Quote:
Depends, might not raise the floor system, might make the walls taller.
Depending on where it was.
  #9 (permalink)
Old 06-12-2008, 07:53 AM
Re: sill plate
Sometimes 2 plates are used with the application of a soft concrete floating floor. like Jib-Crete.
Best
Ron
  #10 (permalink)
Old 06-12-2008, 08:05 AM
Re: sill plate
Ron,
That's Gyp-Crete.
The "Gyp" part stands for "gypsum".
  #11 (permalink)
Old 06-12-2008, 08:13 AM
Re: sill plate
Never ues the stuff. L.O.L.
Jerry its just got to drive you nuts with some of us num-skulls around hear.
Thanks for the correction.
Best
Ron
  #12 (permalink)
Old 06-13-2008, 11:21 AM
Steve Lowery Steve Lowery is offline
Re: sill plate
... the Marx Bros. "Everybody knows there's no such thing as a sanity clause".
  #13 (permalink)
Old 06-13-2008, 03:24 PM
Re: sill plate
Dang it Jerry, that's why I threw in the "etc.", because I knew that was coming.
I should have said "to raise the framing"
  #14 (permalink)
Old 07-13-2008, 09:47 PM
Tim Spargo's Avatar
Tim Spargo Tim Spargo is offline
Re: sill plate
Just to throw in there. Standard would be a single 2x (or 3x) plate with 2 top plates with. PT over concrete and such.
Only thing I can think of with doubling plates.
Haven't built anything with doubled sill on bottom but have built with 3x bottom plate and a few 3x studs at breaks for shear.
On second floor apps, even with doubled plate over certain types of joist spans (?? as mentioned) would leave me with having to attach plates with SDS screws or some hardware, that wouldn't be any fun.
So, in short doubled joists are common as are double top plates.
Tim
Tim Spargo - Inspector and Radon Measurment
  #15 (permalink)
Old 07-14-2008, 08:22 AM
Jerry McCarthy's Avatar
Re: sill plate
When confronted with doubled sill palates installed on the top of foundation stem walls I’m concerned should I see anchor bolting in that the builder used proper length steel anchor bolts to get the required 7 inch depth into concrete. If I don’t see visual evidence of bolting then I’m concerned they may not exist? Either way triggers the appropriate comment in my report. I never framed with single top plates and never actually saw anyone else do it in the 35 years I spent as a builder. The codes do allow it, but only under certain conditions. (imposed loads)
Construction Consultant
  #16 (permalink)
Old 07-14-2008, 10:31 AM
Re: sill plate
That was the first time i'd seen it too. And went in as a 3 stooges type application if I remember correctly.
YouTube - Jerks of All Trades - 3 stooges Pilot never aired part 1
Home inspection
Similar Threads
flashing at bottom plate Jerome W. Young Exterior Systems: Home Inspection and Commercial Inspection 3 05-21-2008 03:54 AM
Need Opinions - Unsupported Sill Plate Bob Sisson Structural Components: Home Inspection and Commercial Inspection 7 04-02-2008 06:48 PM
Column top plate Jeff Beck Structural Components: Home Inspection and Commercial Inspection 7 02-21-2008 06:37 AM
Window sill dan orourke Building Envelope: Home Inspection and Commercial Inspection 1 10-28-2007 01:03 PM
Condo/Townhouse Boiler Plate Tim Moreira Reports 3 10-16-2007 06:43 AM
vB.Sponsors
Ad Management by RedTyger
