Old 06-30-2008, 09:33 PM
mathew stouffer mathew stouffer is offline
Joist question
Is this type of joist rated for exterior exposure. Several joists were sistered under a hot tub and the water from the tub was deteriorating the joist. But,I was curious what everyone knows about these.
Old 06-30-2008, 10:07 PM
Re: Joist question
Wow, all kinds of problems there....
Leaking tub of some type
Boring in the lower 1/3 of the joists
And no, I'd say that's not an 'outdoor' piece of lumber. However, I think the decking might give out before the joist.... kind of a race, really
That's a glue-lam of sorts, definitely not intended for outdoor use... under a hot tub.
Old 06-30-2008, 10:31 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: Joist question
Weyerhaeuser makes it .
http://www.ilevel.com/literature/TJ-7000.pdf
Also as treated / exterior applications ( PSL )
http://www.ilevel.com/literature/TJ-7100.pdf
Billy J. Stephens HI Service
Old 07-01-2008, 05:14 AM
David Banks David Banks is offline
Re: Joist question
Second PDF posted by Billy says PSL for exterior use.
Rusty nails not good.
Is deck bolted to house. Proper flashings?
Dave
Old 07-01-2008, 07:50 AM
Re: Joist question
Thanks for the info. I spoke to a rep today and he said they have to be wolmanized for exterior use. Also the hole drilled is not an issue. Thanks for the web site, very helpful.
Mat
  #6 (permalink)
Old 07-01-2008, 09:57 AM
Jerry McCarthy's Avatar
Re: Joist question
If those drilled holes are within 2 inches of the bottom of those framing support members its a violation of IBC 2308.10.4. (2007 CBC same)
Construction Consultant
  #7 (permalink)
Old 07-01-2008, 10:13 AM
Ron Bibler Ron Bibler is offline
Re: Joist question
Good eye Jerry.
Best
Ron
  #8 (permalink)
Old 07-01-2008, 01:01 PM
Re: Joist question
What if the joists are sistered, does that negate the detrimental effects of holes being drilled in the lower third.
Similar Threads
Rim Joist Question Sean Bacon Exterior Systems: Home Inspection and Commercial Inspection 9 03-01-2008 09:39 AM
Floor Joist? Clay White Structural Components: Home Inspection and Commercial Inspection 4 11-03-2007 06:37 PM
Joist span wayne soper Exterior Systems: Home Inspection and Commercial Inspection 2 05-18-2007 12:08 PM
Scissor joist Mike Schulz Sub-Structure: Home Inspection and Commercial Inspection 9 04-11-2007 08:41 PM
Joist support Francis Turak Structural Components: Home Inspection and Commercial Inspection 14 04-04-2007 06:15 PM
vB.Sponsors
Ad Management by RedTyger
