Old 08-04-2008, 05:03 PM
john dennett john dennett is offline
Steel I beam cut in half
Just wanted to see what comments I could get about this. I wanted to be able to give my client some decient information but I have been unable to get any hard information from the books I have. What I have is a steel beam which appears to have been cut. In the first pic the cut is directly above the expansion tank over the water heater. There is about 2 feet of cantilevered beam on the right side and about 10 feet on the left. In the second pic you can see a close up of what I think has been cut. The left side resting on three 2x4s. The next real colum to the left is a 4inch steel post about 10 feet away. Am I crazy or is this way wrong??? By the way there are two stories about this.
Old 08-04-2008, 06:00 PM
wayne soper's Avatar
Re: Steel I beam cut in half
And how do you think they were cut? That straight? And Why would anyone want to. Do you think the weight of those beams may have caused the SE to decide on 2?
Old 08-04-2008, 06:32 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is online now
I'd like to hear the second story, please. I don't like the first one.
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
Old 08-04-2008, 06:36 PM
The beams look like they were installed like that, not necessarily cut afterwards. Should have better support than 2x4's
- are there footings under the post and 2x4
- open framing, no fire separation at hwt
- is that cpvc tied to the copper at hwt, proper couplings? does your code allow that crap?
- what's up with the flex hose, going to a register?, not properly secured
- is that a GFI those pumps are plugged into?
- freon line doesn't look secured
- whether the cantilever on the beam is ok for 2' or 10'(unlikely) will depend on beam weight (W20,25,30etc) and height. Call for SE or Arch to spec if ok
- check if your plumbing code calls for a TEE at change of direction for clean-out instead of 90's
Just a few thoughts, good luck
847/736-9975
Markus Keller
Old 08-04-2008, 07:34 PM
Michael Thomas's Avatar
I would really expect to see those supported by permanent steel columns - my vote is a field mod by the builder. Check the plans, would be my advice.
  #6 (permalink)
Old 08-04-2008, 07:43 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
John,
Were does all the tangled cord go and what does it supply power to ?
Billy J. Stephens HI Service
  #7 (permalink)
Old 08-04-2008, 08:17 PM
a lot of the plastic pipe and low voltage wire is from central vac. Yeah the copper to plastic is typical around here. No that was not GFCI to the sump and what I was trying to say but failed to do was that this is in the basement of a two story home.
  #8 (permalink)
Old 08-04-2008, 08:20 PM
One last thing, the reason I though it had been cut was the wood above has a kerf at the exact same location. Its hard to see in the pic but it is there.
  #9 (permalink)
Old 08-05-2008, 04:19 PM
Steven Turetsky's Avatar
Steven Turetsky Steven Turetsky is offline
The cantilever dosen't bother me, but the steel beam on wood supports does.
homeinspectionsnewyork.com
eifsinspectionsnewyork.com
  #10 (permalink)
Old 08-06-2008, 10:15 AM
Darren Miller's Avatar
Darren Miller Darren Miller is offline
When a beam or column is cut in the field, it's usually 'burned' with a toch. I see no evidence of that.
Darren
Succasunna, NJ
www.aboutthehouseinspections.com
Similar Threads
steel I beam daniel nantell General Chit Chat: Home Inspectors & Commercial Inspectors 2 07-14-2008 03:51 PM
half breakers not allowed? John Arnold Electrical Systems: Home Inspection and Commercial Inspection 3 12-21-2007 05:45 PM
Foundation Steel? dan orourke Structural Components: Home Inspection and Commercial Inspection 8 09-11-2007 06:08 PM
Cut End on Steel I Beam Nick Ostrowski Structural Components: Home Inspection and Commercial Inspection 3 05-22-2007 11:57 AM
Steel framing Phillip Stojanik Structural Components: Home Inspection and Commercial Inspection 6 04-14-2007 01:21 PM
vB.Sponsors
Ad Management by RedTyger
