    Rick Maday's Avatar
    Rick Maday Guest
    Default Crawlspace stuff
    Saw this in a crawl. 1950's era home.
    Looked and felt like insulation (foamy), but it was behind what was left of the vapor barrier. Shouldn't the vapor barrier be on the wall and this stuff on the VB, or won't it stick to the VB?
    Any comments, info on this stuff?
    If it's mold, they have a hell of a problem, as it was all over the place.
    Also, what could the stuff on the bottom of the duct be? It was only in a couple of places.
    TIA
    Inspection Referral SOC
    Default Re: Crawlspace stuff
    It's hard to tell... the 4th pic is the most help and it looks like mold. I see white mold on damp soil a lot in my area. If it's an overall damp space that could explain it. Whenever I get a damp crawl like that about 9/10 times there will be insect damage.
    Does it appear to be sprayed on the perimeter walls, and are those walls concrete?
    Mold needs food as a rule, something organic to grow on.
    Philip's Avatar
    Philip Guest
    The vapor barrier always goes to the warm side of the house. If the moisture escaping from the interior is trapped between the insulation and the barrier the condensation takes place within the insulation and nothing good happens when that occurs.
    Rick Maday's Avatar
    Rick Maday Guest
    Yes and Yes
    Quote Originally Posted by Rick Maday View Post
    Yes and Yes
    My guesses then are that a sprayed on insulation, cellulose, maybe, has become moldy. The duct has some tarnish on it brought on by condensation. Wet crawlspace, inadequate ventilation. Finally, I guess this won't be an easy fix.
