09-24-2010, 02:17 PM #1
I Joist modification/delamination
Came across a modification to a TJI Joist today in the first two pictures and delamination near the bearing point in the third picture. It looks like the modification was needed for a change in direction and the I Joist rests on a 6 x 16 LVL beam. I always heard that in no way can an I Joist flange be altered.
Any thoughts on how to write this up? What issue is the delamination.
09-24-2010, 03:44 PM #2
Re: I Joist modification/delamination
End bearing support on the angled section looks suspect Sidney. It also appears there may be some moisture issues at play there which may have something to do with then delamination you saw. The top half of the I-joist and subfloor in that 1st pic look dark and stained.
Last edited by Nick Ostrowski; 09-24-2010 at 05:46 PM. Reason: referred to wrong photo in original post
09-24-2010, 04:39 PM #3
Looks like this house may have been left unfinished with maybe just the first deck completed for a period of time.
09-24-2010, 05:08 PM #4
09-24-2010, 06:38 PM #5
09-24-2010, 06:45 PM #6
If thats the case, just delete;
prior to close of title
