08-07-2007, 07:21 PM #1
PVC pipe terminating in crawl space
I am wondering if some one might be able to tell me what this goes to or what it is for. This is a 2005 built home the PVC pipe is below the kitchen area. I am not shure how to write it up or if I should even mention it.
08-07-2007, 08:10 PM #2
Re: PVC pipe terminating in crawl space
Yes you write it up. Simply say that you do not have a clue as to what it's purpose is.
10-15-2007, 04:37 AM #3
How about an over flow for a water heater. Is there a water heater in the kitchen?
10-15-2007, 05:19 AM #4
Well, they were so thoughtful that, when they installed the pipe, they push the insulation down with it. Nice.
There is a brow stain at the end of the pipe and on the plastic below it.
While I do not know 'what' it is, I do know that 'no pipe' is allowed to drain to the crawlspace.
I really like those 2x4 studs right behind it, look just jammed up against a concrete footing and another 2x4 above it ... that 2x4 above it has little strength laid flat-wise like that, and what's to keep those vertical 2x4s from moving and falling out?
10-15-2007, 06:34 AM #5
Discharge from down-draft range fan? Not that it should terminate in the crawl, of course.
You definitely want to include it in your report even if you have no clue.
