Results 1 to 9 of 9
Thread: to bracket or not to bracket
09-02-2011, 12:54 PM #1
What do you think, I think it needs to be prevented from falling over with brackets or mechanicle strapping
09-02-2011, 01:13 PM #2
Re: to bracket or not to bracket
What are we looking at?
09-02-2011, 01:33 PM #3
Here is what NC says:
R407.3 Structural requirements.The columns shall be
restrained to prevent lateral displacement at the top and bottom
ends. Wood columns shall not be less in nominal size than 4
inches by 4 inches (102 mm by 102 mm) and steel columns
shall not be less than 3-inch-diameter (76 mm) standard pipe or
approved equivalent.
Exception:In Seismic Design Categories A, Band C columns
no more than 48 inches (1219 mm) in height on a pier
or footing are exempt from the bottom end lateral displacement
requirement within underfloor areas enclosed by a
continuous foundation.
09-02-2011, 01:56 PM #4
Scott, Main beam end where it meets the chimney structure.
Sitting on a post with no support to prevent lateral movement to the sides.
09-02-2011, 02:11 PM #5
I don't see any means of attachment of the beam to the column either.
09-02-2011, 02:21 PM #6
Yeah, that too! and the ends that are in pockets are supported with 1x3 pieces standing on end.
09-02-2011, 05:41 PM #7
09-02-2011, 06:53 PM #8
Wayne
I would suggest an angle bracket or strap anchored to the triple floor joist above similar to the attached picture.
09-02-2011, 07:22 PM #9
thanks, very good suggestions. 4 year old house, kinda slipped through the cracks i think. nice house, but alot of stupid design flaws.
