Thread: Cinder Block
05-23-2012, 07:40 PM #1
Cinder Block
Hi guys,
Any of you use any boiler plate for the difference between concrete block and cinder block?
Did a house today and alot of areas had been repaired where cinder block has failed in the past and cobncrete block was installed.
Looks Ok now , but buyer wants to raise the roof and add weight.
Of course a structural engineer should be coming for that.
What I am interested in is any kind of standard comment you use for this type of structure and repairs.
Wayne
05-23-2012, 09:48 PM #2
Re: Cinder Block
I just call them CMU's. The cinder block is made with the fly ash. I've heard that the concrete ones are more durable. I leave the rest up to the engineer.
05-24-2012, 05:36 PM #3
Re: Cinder Block
so what you are saying is if you see cmu's you recommend a structural engineer?
I feel I owe my clients a better description than "go hire a structural engineer" , i appreciate your comment though, so thanks
wayne
05-24-2012, 08:16 PM #4
Re: Cinder Block
No what I'm saying is that I don't call one cinder or concrete but use CMU. If they are falling apart and they are load bearing I would recommend and engineer.
05-25-2012, 06:44 AM #5
Re: Cinder Block
Thanks for clearing that up
