Thread: Cinder Block
    Connecticut
    Default Cinder Block
    Hi guys,
    Any of you use any boiler plate for the difference between concrete block and cinder block?
    Did a house today and alot of areas had been repaired where cinder block has failed in the past and cobncrete block was installed.
    Looks Ok now , but buyer wants to raise the roof and add weight.
    Of course a structural engineer should be coming for that.
    What I am interested in is any kind of standard comment you use for this type of structure and repairs.
    Wayne
    Mar 2011
    Sparks,NV
    Default Re: Cinder Block
    I just call them CMU's. The cinder block is made with the fly ash. I've heard that the concrete ones are more durable. I leave the rest up to the engineer.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Connecticut
    so what you are saying is if you see cmu's you recommend a structural engineer?
    I feel I owe my clients a better description than "go hire a structural engineer" , i appreciate your comment though, so thanks
    wayne
    Mar 2011
    Sparks,NV
    No what I'm saying is that I don't call one cinder or concrete but use CMU. If they are falling apart and they are load bearing I would recommend and engineer.
    Nevada IOS#1730
    Connecticut
    Thanks for clearing that up
