    May 2012
    Western Maryland
    Default Builder is the AHJ
    So, the builder is the mayor of a tiny (pop 454) town that opted out of adopting building codes and is technically the AHJ. The buyer is related by marriage and feels a little uncomfortable by the lack of inspections, but doesn't want to start a family feud unless he has to. Do you hear the banjos playing yet?
    Anyway, I told my client that it is too late for construction progress/code inspections for most things, but I'll see what I can see. He just wants someone (anyone!) to give him some level of comfort.
    Fortunately, things aren't too bad overall, but the geotechnical aspects (footing, foundation, and drainage) have issues:
    1. Full height CMU foundation wall on continuous spread footing that has no interior slab, backfill, or other lateral bracing at the footing (moisture build-up from not-yet-installed gutters; soils are typically non-expansive);
    2. 12" sonotube pier footings about 12" thick set on top of gravel, also no lateral containment (plus not secured at top or bottom).
    I'll be commenting on these and other issues, but I'd like to hear peoples' take on the severity of these items.
    Thanks!
    Attached Files Attached Files
    Mark Fisher
    Allegany Inspection Service - Cumberland MD 21502 - 301-722-2224
    Home Inspections, Mold Testing, Thermal Imaging
    Apr 2007
    state of jefferson
    Default Re: Builder is the AHJ
    all three are wrong here. top of footing needs to be flush or below grade under the building. interior footings a minimum of 6" below ground.
    Mar 2012
    North Central Texas
    Texas Inspector
    http://www.texasinspector.com
    Nov 2011
    Oregon, USA
    Probably the only good news you had for the buyer was there's a good chance the groundwater infiltrating the block walls could be relatively clean, at least for now.
