Results 1 to 10 of 10
Thread: Settling House
02-11-2013, 04:37 AM #1
Settling House
My wife and I are looking to purchase a home that is 21 years old. Our inspector noticed some cracks in the floor and the brick. He advised to have a foundation specialist come out and look at it. Typically here in the Huntsville/Madison AL area we have red clay. I put a laser on the back end of the house and found about a 1/4" variation over a 20' span on the end section of the house. On the bay window area at the back of the house I found a 3/16 variation in the mortar line. The house is a slab on grade. It's approximately 2800 sq ft under roof including the garage.
02-11-2013, 05:43 AM #2
Re: Settling House
Any interior wall cracks?
Tile flooring?
02-11-2013, 05:57 AM #3
Re: Settling House
The floors are vinyl and carpet. I didn't see any cracks on the walls or ceilings. They could have fixed them but when they painted the house they used a brush throughout. The paint is rather thin so I didn't see any obvious places that had been patched. It being our first home makes me a little nervous about these things.
02-11-2013, 05:59 AM #4
Re: Settling House
What is the standard deviation of your laser? Meaning error factor of X over Y feet.
You may just have a variation in the masons laying the brick.
02-11-2013, 06:13 AM #5
Re: Settling House
02-11-2013, 12:32 PM #6
Re: Settling House
Some of the brick work looks a bit "amateurish" (non-uniform mortar lines, mortar slop, rake inconsistencies, etc.), and may have been there from Day 1. If the inspector meant "engineer" instead of someone who wants to make money "fixing" your foundation when it might not need it, by all means pay for bringing a qualified guy in. Before spending the $$$ though, it wouldn't hurt to take a closer look at a few of the neighboring brick homes' exteriors (with owners' permission, of course), to see if similar anomalies are present elsewhere in the neighborhood.
02-11-2013, 03:32 PM #7
Re: Settling House
The house has had some settlement, that is easily seen at the window where it has pulled from the brick. Will it do more? Nobody can or will tell you that. It looks like it is sitting on a fill lot, so it might have compacted the soil enough that it has done all it is going to do. But again, that is a SWAG.
With no interior wall cracks and if all of the door and window open and close properly it is most likely not all that bad of an issue.
Your home inspector is going to be your best source for information as they have seen it first hand.
I did notice that the weep holes have been added to the home after it was built. Weeps should not be drilled into the mortar, they should be made when the brick is laid.
02-12-2013, 10:40 AM #8
Re: Settling House
Foundation guy came yesterday. He wasn't too concerned with what he saw. He did recommend that if anything had to be done it would be in the bay area with 5 piers. He didn't think it needed any now. He said if it were in South Huntsville it would have been a different story. He is the go to guy in our area.
02-12-2013, 10:43 AM #9
02-12-2013, 08:22 PM #10
Re: Settling House
