    Sep 2018
    Ohio
    Atlanta, Georgia
    Default Re: Spalling in Basement Wall
    Long term water intrusion. Most common cause is improper gutter maintenance and downspouts not directed away from the home. Next is improper grading. Until you figure out where the water is coming, from you are going to have ongoing water intrusion.
    And I don't see any "spalling" in the photo.
    Spalling is rare in block construction, unless there is a filled cell or filled lintel/bond beam, and even then typically what is seen is not spalling.
    That looks like fungi/algae growing on the wall, cause from the things Bruce pointed out.
    Mar 2017
    California
    Your inspector did not inform you that any water intrusion like that is serious and you should be concerned?
    Ok, if not then I will, that water intrusion is serious and you should be very concerned about it.
Tags for this Thread
