Results 1 to 12 of 12
Thread: New To Me
    Connecticut
    Default New To Me
    Any of you seen this before? 8 inch holes around the entire crawl space. Some have a hose connected that looks like it should connect to a small pump. Most are filled with foam stops but are in no way water tight. Look like they would let water in to me. Any Ideas? Ground was very wet outside and crawl was bone dry.
    Tom Dietrich's Avatar
    Tom Dietrich Guest
    Default Re: New To Me
    They might not have decided where, or how water and sewage would enter and exit the house. So they put sleeves in everywhere?
    Just a wild a** guess. Not a mind reader.
    tom
    I know it can be annoying when someone comments on something else in your photos, but, since I have no idea what the sleeves are for -
    it looks like there's no air gap on the sides of that beam.
    Maybe this was their idea of crawl space ventilation.
    New Mexico
    A way to let water into the sump pump area so it wouldn't collect all along the outside? Was there a sump pump in the crawl? Is it common for people to concrete the floor of the crawl space where you live? That would be nice, but I've never seen it here.
    Connecticut
    Yes common to concrete the flor. No sump pit. Broker made comments about the super duper water proofing method.
    I was thinking maybe a water tight drain system around the home that would drain water out but not let it in, but. That's a big BUT. Bigger than a brokers but for sure and that's BIGGGG.
    Vancouver - Canada
    very odd... looks like they're using the crawlspace as a sump. The crawlspace may never see any water (depending on soil and climate conditions) if the perimeter drains are in place and functioning correctly.
    Brandon Chew's Avatar
    Brandon Chew Guest
    Quote Originally Posted by Joe Klampfer View Post
    That is my take on it as well.
    Aaron Miller's Avatar
    Aaron Miller Guest
    Wayne:
    Just a very large catch basin for the sump pump. Around here they don't go to those extremes, unfortunately. We generally do not see concrete in a crawl except in the perimeter and interior beams. All else is soil and usually wet. If they install a sump pump they simply dig little trenches that lead to the pit (sometimes).
    Looks like a good install to me.
    Aaron
    Vancouver - Canada
    Wayne:
    Aaron
    except for the intent... up here concrete skim-coat over a poly vapor barrier on the crawlspace floor is normal but those large drain pipes blowing through the foundation walls are not. We're quite damp up here (north of Seattle) and try to keep moisture out and away.
    Connecticut
    This home is in a river front flood plain and I've inspected many but never with this system.
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    Was repairing a house following a severe tornado a few years ago. Turns out the house was in a 100 year flood plain. As mandated by FEMA, any structure within that area had to conform to their standards when repaired. This included no basement allowed, if there were an existing basement they wanted the mechanicals moved upstairs, floor drains sealed, and the basement filled with gravel, thereby rendering it non usable. Construction of the new detached garage required flood vents in the foundation at ground level thereby allowing flood waters to pass thru the structure. Maybe what you have is someones interperetation of that rule.
