10-10-2008, 05:09 PM
screwy stem wall
Something obviously went wrong during construction, and the structure didn't fit over the stem wall as designed. The siding rests on the stem wall instead of overlapping it. There is also an area on the left side of the house where a lower portion of skirting and framing is way out of plumb. One corner of the stem wall is not level, and has been patched. This house was built in 2002. Any thoughts???
Ron Bishop
Shasta Lake, Ca.
10-10-2008, 07:02 PM
Re: screwy stem wall
You mean comments other than pointing out the obvious poor workmanship in general?
OK...
1. I can't tell what is going on in photo #1 with the stair-stepped foundation. Certainly doesn't appear as though it was designed that way, however.
2. Photo # 2 shows rot-damaged siding...and more importantly, what appears to be a cold joint in the foundation. And what's with the vent which allows water to penetrate exposed edges of the siding?
3. ANY horizontal (or nearly so) exposed foundation edges are water traps and will lead to deterioration of the framing members. Admittedly, in photo # 3, the wall is out of plumb. There would be less exposed horizontal foundation "ledge" if the wall was plumb.
All in all, it looks like very haphazard work. Putting it nicely, I would suspect that the rest of the house is similarly questionable. Better look at it VERY closely...
10-10-2008, 07:51 PM
HeyMoe, what could be so hard about pouring a foundation? NUKNUKNUK
LOKATDAGROUSE LOOKATDAGROUSE.
10-11-2008, 07:09 AM
On my new construction projects I frequently see situations where the foundation design and the building design don't fit each other. They are designed by different people using different software and nobody compares them. When this happens, framers get very creative to make the compensation. This appears to be what happened here. If that is the case, the slab contractor did his job . . . the general contractor screwed up.
Darrel Hood
DILIGENT PROPERTY SERVICES
10-11-2008, 10:22 AM
We used to call that a "twelve-pack pour."
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| BEES IN THE WALL |
Ron Bibler |
Tools and Equipment |
6 |
05-09-2008 07:19 PM |
| box cut into block wall |
william siegel |
1 |
04-28-2008 08:53 PM |
| Single Wall vs. Double wall vent pipe |
Jonathan Clevenger |
2 |
03-08-2008 11:10 AM |
| SIngle wall? |
Jeff Eastman |
1 |
07-03-2007 12:04 AM |
| Wall plumb |
John Stephenson |
Building Interior: Home Inspection and Commercial Inspection |
2 |
06-03-2007 01:34 PM |
Ad Management by
RedTyger
