Old 06-05-2007, 02:29 PM
wes owens wes owens is offline
Sprayed foam in crawlspace
I had my first encounter with spray foam insulation today.
It was in a crawlspace and it was a mess.
I found several floor-joist under the master bedroom that were soft and starting to decay and was wondering if they may have sprayed the foam when the moisture content in the wood was high.
This may have locked moisture in, causing it to decay the wood.
Any thoughts?
"I reject your reality and substitute my own!" - A. S.
Absolute Home Inspections, LLC
Home inspection
Old 06-05-2007, 02:33 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Sprayed foam in crawlspace
More evidence that spray foam should not be sold to anyone that cannot show evidence of knowledge of the proper use of spray foam.
Bruce Breedlove
www.avaloninspection.com
Old 06-06-2007, 07:08 AM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
What an absolute mess. I would defer the whole thing.
NM cable, waste lines, beams, rotted joists all covered in insulation and everything else that is not visible...
Looks abolutely horrible.
Old 06-08-2007, 03:38 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
I have to ask myself WHY did they do that, and WHAT is covered up. That and tell my client to run like hell away from it.
JF
Old 06-08-2007, 04:34 PM
Quote:
JF
Reminds me of a course I took in hazardous material clean-up, don't know if I still have the two books or not, but one book showed pictures of shapes of trucks and symbols, the other book told what to do minimum until the clean-up crews arrived, and those tanker trucks with the rounded ends, you know, the ones under pressure, you could look that up in the second book and it would tell you how fast to run how far away minimum , ... or, you could spend that time running as fast as you can as far as you can!
Pull out the book and point to that truck shape and say 'See this truck shape? See that house? Run fast and far!'
  #6 (permalink)
Old 06-12-2007, 11:42 PM
The foam is a total mess.... the only place I've ever seen anything like that is on the underside of a house on stilts.
Speaking of unorthodox crawl insulation, has anyone ever seen loose-fill used? This was just crazy! I had a huge dispute with the seller on this one. This stuff was just falling down everywhere. I've never seen anything like it.... I have never been able to find an inspector who has ever seen this before. Anyway, the picture is attached.
  #7 (permalink)
Old 06-13-2007, 01:22 PM
Matt,
No, I have never seen loose fill insul. used that way. I have two questions about that:
1) How did they get the insulation in place?
2) Why would anybody do that?
The things we see!
Bruce Breedlove
  #8 (permalink)
Old 06-13-2007, 05:51 PM
James Duffin James Duffin is offline
This type of foam is used in attics on the bottom of roof sheathing but have never seen it used in a crawl space. It works great in an attic. Needs no ventilation and makes it a conditioned spaced....like a conditioned crawl space.
  #9 (permalink)
Old 06-13-2007, 10:12 PM
Quote:
Originally Posted by Bruce Breedlove View Post
Matt,
The things we see!
They used a mesh netting of sorts... but it really didn't work around plumbing, or posts, or really anywhere for that matter. The seller tried to send some goons down there with a roll of duct tape a couple times and it didn't work at all. Finally, they went down with some better mesh and an air compressor staple gun. It worked better but was still just a poor design. It's funny how the whole concept of gravity escapes people.
The funniest part of the entire story is that I ended up marrying the buyer of the house! No joke, I went back for so many re-inspections I got to know her pretty well... well enough to start dating and eventually get married.
I usually try to distance myself from these buyer vs seller pissing matches but this was just crazy... the seller was really being totally unreasonable and I felt sorry for the buyer. It's good to know standing by your guns can really benefit you sometimes Needless to say I always smile when I hear about crazy crawl space insulation.
  #10 (permalink)
Old 06-14-2007, 01:44 AM
Quote:
Now that's interesting.
Bruce Breedlove
  #11 (permalink)
Old 07-01-2007, 09:22 PM
Kenton Shepard Kenton Shepard is offline
Spraying foam on the underside of the roof of an unvented attic is gaining widespread acceptance. The attic becomes part of the conditioned space. Looks like they might have been thinking along those lines. The moisture question is the same with the attics... when the roof leaks, how does that water dry? Seems like the only answer is the same for both... diffusion through the sheathing and membrane. 'Course in the roof it still has to get past the roof-covering material.
In this particular case... yep, it's a mess... disclaim.
Similar Threads
Ground in crawlspace Jeff Eastman Sub-Structure: Home Inspection and Commercial Inspection 27 06-13-2007 04:46 PM
Holding up the crawlspace walls Anthony Alderman Sub-Structure: Home Inspection and Commercial Inspection 8 06-08-2007 02:43 PM
Crawlspace vent fan Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 05-18-2007 08:13 PM
Great Foam Insulation John Stephenson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 05-18-2007 11:53 AM
From the old board, Sprayed Panels Tim Moreira Electrical Systems: Home Inspection and Commercial Inspection 2 04-02-2007 06:01 AM
vB.Sponsors
Ad Management by RedTyger
