Old 09-24-2009, 05:36 PM
mathew stouffer mathew stouffer is offline
Check out this gem
Just when you thought you have seen it all. I had to do a double take at the waste line running under the "footing".
HomeGauge Reports
Old 09-25-2009, 08:02 AM
Wayne Carlisle Wayne Carlisle is offline
Re: Check out this gem
Ummmm....I think I may be blind. I don't see a waste line running under the footing. Please point me in the right direction!
Old 09-25-2009, 08:38 AM
Last photo, look to the lower left.
Old 09-25-2009, 08:39 AM
Gunnar Alquist's Avatar
Quote:
Wayne,
Last photo. Under the pier/footing.
We have enough youth, how about a fountain of Smart?
Old 09-25-2009, 08:41 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
OMG!
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
  #6 (permalink)
Ohhhhhh thanks, I was looking for a white pipe..... Don't see any black (ABS??) sewer pipes in our area.
  #7 (permalink)
Old 09-25-2009, 09:18 AM
I have a better photo but forgot to put it in.
  #8 (permalink)
Old 09-25-2009, 10:39 AM
James Foy James Foy is offline
Were they bracing an overspan? Just wondering if this was done after initial construction.
Reminds me of a house I inspected where the plumber wanted to run the drain for about 4' in the footing. I wrote the correction and he had changed it to about 16". Wrote a second correction. "But I thought you said I could run it for short distances". Sigh.
http://equityguy.blogspot.com/
If I could have convinced more slaves that they were slaves, I would have freed thousands more. Harriet Tubman
  #9 (permalink)
Old 09-25-2009, 11:54 AM
Dana Bostick's Avatar
Dana Bostick Dana Bostick is offline
You can cross a footing perpendicular but it must be protected and sleeved.
"Political Correctness is a doctrine, fostered by a delusional, liberal minority and rabidly promoted by an mainstream media,which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
  #10 (permalink)
Old 09-25-2009, 01:08 PM
Yes, Dana you can cross a footing, but you can not run the pipe in the footing.
  #11 (permalink)
Old 09-25-2009, 01:40 PM
Jerry Peck's Avatar
Quote:
Actually, if is engineered properly, you can.
The whiz-bang of that engineer's stamp, signed and sealed, will do it.
The code specifically addresses going through foundation walls, and going under footings, thus, using the allowable 'going under footings' the engineer can design the footing to allow for the pipe to go through the footing - as long it the rational analysis of the engineering works out.
Not the brightest thing to do, but I would rather see it go through a footing than under the footing - either way, though, the footing must be designed so as to not put any pressure on that pipe and the pipe must have clear passage through/under the footing.
  #12 (permalink)
Old 09-25-2009, 02:12 PM
Yes, the lovely magic of an engineer's stamp. I've even witnessed them approve an onsite water retention system in the 45 degree footprint of footing without the manufacturer's recommended moisture barrier or approval to be used in that area.
Maybe I should post all statements with the caveat: "without an engineer's stamp of approval".
I also got to witness an electrical engineer's approval of a plan that neglected a common lockout device that nearly killed a man. The engineer told the plan checker (former commercial electrical installer) that he wasn't an engineer and it wasn't required. Little comfort to the guy who was nearly killed. Luckily it was a major commercial chain that is paying handsomely for his medical. Maybe they're sublimating it to the engineer's E&O, but I doubt that was enough to cover some truly horrific burns.
Sorry for the tangent.
  #13 (permalink)
Old 09-25-2009, 07:08 PM
I suppose I could have expanded on that a bit. Yes, it can be done if done properly with proper design to prevent the pipe from being crushed. I have done it. The specs are available should that issue come up in your universe.
But....in no case is it ever allowable to run it parallel in the surcharge area or actually IN and parallel to the footing itself.
DanaB (former plumbing contractor)
  #14 (permalink)
Old 09-25-2009, 07:22 PM
Nick J. Alati Nick J. Alati is offline
Sometimes you going to that next inspection thinking "Just another Home Inspection" and BAM! There's the prof that there are lot's of different types of people, that think in way different ways (than normal fokes) and why we have to charge so darn much! YES!
  #15 (permalink)
Old 09-27-2009, 11:16 AM
Randy Aldering Randy Aldering is offline
Yes, the highly-rated engineer's stamp. Funny how they will sign anything for the right amount of green. I once called out a garage wall that was so far off the foundation the anchor bolts were waving in the wind, bare as can be. They had substituted several Red Head anchor plates and driven fasteners. Not a single notation on the blueprint at the code office. The voice-mail from the builder offered to pay me "what ever your fee is" to write a letter to my client stating that it was "OK". I never returned the call. About three days later, my client showed me a letter from an engineer, stamped and signed on company letterhead, stating exactly what was "suggested" to me. The word from the code office: "why, they are one of this area's largest builders!" And so it goes.
Randy Aldering, RHI CHI
Housesmithe Inspection
www.housesmithe.com
  #16 (permalink)
Old 09-27-2009, 01:33 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
It's plastic pipe and appears to be a long run. Looks to be easy fix with a couple of fittings at the start point. The section left after re-routing can be used as a subway for mice.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
  #17 (permalink)
Old 09-30-2009, 05:41 PM
Jerry McCarthy's Avatar
What are you guys seeing as a defect with that ABS waste line in that photo?
Leaving the pier-post wood forms in place will make the PCO day as soon as he/she makes their inspection.
Construction Consultant
FREA Home Inspector Insurance
Similar Threads
Check this one out Paul Johnston Electrical Systems: Home Inspection and Commercial Inspection 9 07-10-2009 02:58 PM
Check the Inside of the Oven Rick Hurst Built-In Appliances and Systems: Home Inspection and Commercial Inspection 6 03-27-2009 06:34 PM
Wow...Check this out. Marc M Structural Components: Home Inspection and Commercial Inspection 20 12-09-2008 06:58 PM
Check this old suse out!!! Ron Bibler Tools and Equipment 4 12-06-2008 08:50 PM
Tip 6: Spell Check Brian Hannigan H E L P ! 2 04-18-2007 11:02 PM
vB.Sponsors
Ad Management by RedTyger
