Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 10-04-2009, 12:43 PM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
Pier Graphic
I have spent the past hour looking for a decent graphic depicting a residential foundation drilled pier's rebar placement. Does anyone have something like this they would like to share?
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
Help Support InspectionNews
Old 10-04-2009, 01:26 PM
J Moore J Moore is offline
Re: Pier Graphic
Not sure if this is what your looking for but it's the best I could find.
Jeff Moore
AZ Cert#49250 Level 1 Thermographer
http:www.quantumhomeinspections.com
Old 10-04-2009, 01:27 PM
Re: Pier Graphic
Quote:
Attachment 14338
JM: I guess I was not specific enough. That is for a foundation repair pier and what I need is for an original drilled pier. Thanks.
Old 10-05-2009, 12:36 AM
ben jacks ben jacks is offline
Re: Pier Graphic
Quote:
Are you referring to "star-drill" doweling into a concrete foundation? Or is a pre-drilled pier block what is being referred to? Maybe none of the above. :] rbj
Old 10-05-2009, 03:44 AM
Re: Pier Graphic
Quote:
BJ: I'll attempt to remove the argot block. When one is building a pier and beam foundation one drills holes in the ground, adds rebar, and then fills the holes with concrete. The resulting entities are called piers. I am looking for a graphic depicting the proper placement of the rebar in these drilled piers. I suppose you could also call them augered piers. The IBC does, but no one here ever says "augered".
Something like the picture below, but a line drawing showing the whole hole, if you will.
  #6 (permalink)
Old 10-05-2009, 10:38 AM
Re: Pier Graphic
Thanks for the great pic A.D. I must live a sheltered existance but I am learning everyday.
Great stuff. 8j
  #7 (permalink)
Old 10-05-2009, 03:35 PM
Jerry Peck's Avatar
Re: Pier Graphic
Aaron,
It would vary depending on the engineering.
The size of the vertical steel, the number of vertical steel bars, the size of the hoops, the spacing of the hoops from the bottom and the top and each other will be specified by the engineer, which all depends on what is going to be placed on those piers, which also has to do with the number of piers installed.
  #8 (permalink)
Old 10-05-2009, 04:29 PM
Re: Pier Graphic
Quote:
Aaron,
JP: While this may be so, the minimal standards are set forth in IBC 1810, 1812, et al.
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Pier Footings Rick Cantrell Sub-Structure: Home Inspection and Commercial Inspection 20 09-10-2009 04:45 AM
WARNING: graphic video of an electrocution on roof of a train Jerry Peck Electrical Systems: Home Inspection and Commercial Inspection 5 06-04-2009 01:27 PM
Pier to post connection Terry Sandmeier Structural Components: Home Inspection and Commercial Inspection 17 01-21-2009 03:56 PM
decking pier to post connections David Camilleri Introductions By New Members 2 09-28-2008 08:39 AM
Block Pier Construction Greg Jenkins Sub-Structure: Home Inspection and Commercial Inspection 15 08-01-2007 10:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
