Old 10-16-2009, 06:19 PM
wes owens wes owens is offline
Gap between wall and foundation
Found this today.
A gap between the brick veneer wall and the concrete foundation blocks.
There was daylight shining through the gap into the crawlspace, and when I crawled out and looked at the exterior wall, there is a crack in the brick at the same area.
Short of recommending a S.E. evaluate it, what could I recommend for repairs?
"I reject your reality and substitute my own!" - A. S.
Absolute Home Inspections, LLC
IC Home Inspection Report Writing
Old 10-16-2009, 06:39 PM
Gunnar Alquist's Avatar
Re: Gap between wall and foundation
Quote:
Originally Posted by wes owens View Post
Found this today. A gap betwee n the brick veneer wall and the concrete foundation blocks. There was daylight shining through the gap into the crawlspace, and when I crawled out and looked at the exterior wall, there is a crack in the brick at the same area. Short of recommending a S.E. evaluate it, what could I recommend for repairs?
If this is not structural and there is no other problem, such as cracked or settling foundation, defer to a masonry contractor.
We have enough youth, how about a fountain of Smart?
Old 10-16-2009, 06:42 PM
Jerry Peck's Avatar
Wes,
Someone forget that those had to be fully filled with concrete, and have a proper brick ledge on top, and not expose the interior cells to collect water, and the block head joints are not even fully bedded as required, and ... (it just keeps getting worse the longer one looks at it)
Old 10-16-2009, 06:47 PM
Looking at my post I realized I forgot to mention that there are several cracks in the brick in different areas around the home.
The crack starts below the adjacent window and extends down to the top of the concrete block where the gap is at.
It is the widest at the gap between the block and the bottom of the brick wall.
It looks like the gap was trying to spread because there is no support under the bottom of the brick wall due to the gap between the wall and the concrete block.
Old 10-16-2009, 06:49 PM
So what would you recommend for repairs?
Could filling in the gap prevent further cracking in the brick?
  #6 (permalink)
Old 10-16-2009, 07:07 PM
Jerry Peck's Avatar
*I* would not recommend repairs, I would recommend ...
Quote:
... for their repairs.
As I am seeing the photos, I suspect it will be costly to repair, and possibly quite involved.
I'm thinking taking the brick out around the bottom in sections, digging out whatever is in the block (looks like mortar), making sure there is steel in it, properly filling with concrete, may even need to cut the webs out to make bond beam block, forming a proper brick ledge, then relaying the brick to the supported section. repeat around the entire house.
  #7 (permalink)
Old 10-16-2009, 07:13 PM
That does sound expensive.
  #8 (permalink)
Old 10-16-2009, 10:24 PM
Richard Pultar Richard Pultar is offline
remove and replace , any repair is useless..
what would Holmes do ?
  #9 (permalink)
Old 10-19-2009, 03:40 PM
Randy Aldering Randy Aldering is offline
Recommend further evaluation by a structural engineer, your original idea it seems. Nothing less. It appears to be a disconnect, jack, and replace job. Only the S.E. is likely to be able to hammer that home.
Randy Aldering, RHI CHI
Housesmithe Inspection
www.housesmithe.com
  #10 (permalink)
Old 10-19-2009, 04:27 PM
Quote:
Either an SE or at the least a foundation company. I fr one think an SE is overkill. Foundation comaonies deal with settling concerns and draw up repairs every day of the week. A foundation company can evaluate and also give a quote for repairs. The old addage that you should not have the foundation company do the eval because they are looking for the foundation repair job. I don't hold to that in the slightest. Almost everyone gets at least 2 if not three estimates for repair so the FC is going to be as straight on as possible.
Call for a foundation company to come and take some measurements and visual eval for repairs
"You can see daylight straight into the crawl" "there are cracks on all sides of the home"
Yes a furhter eval and estimate for repairs in definately necessary and yes it is structural.
Ted Menelly
Castle Home Inspection Services
www.inspectmycastle.com
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Similar Threads
foundation wall thickness John Dirks Jr Sub-Structure: Home Inspection and Commercial Inspection 5 03-02-2009 03:54 PM
Bulldozer Scraping Foundation Wall Sean Bacon Structural Components: Home Inspection and Commercial Inspection 7 09-23-2008 10:04 AM
Opinions on block wall foundation Stan Vaughn Sub-Structure: Home Inspection and Commercial Inspection 7 05-12-2008 07:35 AM
Exterior wall & foundation RobertSmith Building Envelope: Home Inspection and Commercial Inspection 2 12-15-2007 09:08 AM
Dryer outlet in foundation wall Mr. Davidson Electrical Systems: Home Inspection and Commercial Inspection 4 10-17-2007 06:20 AM
vB.Sponsors
Ad Management by RedTyger
