Old 10-29-2009, 05:51 PM
daniel nantell daniel nantell is online now
wiring in unfinished basement area
You see a lot of exposed nm cable in unfinsished basements areas, I always recomment they placed in conduit or finshih off with drywall to protect the wiring. How high does it need to be protected, I thought it was 7 feet .
dmn
Old 10-29-2009, 06:53 PM
ken horak ken horak is offline
Re: wiring in unfinished basement area
The 2008 NEC article 334.15 does say that exposed cable run on walls in unfinished basement areas, shall be protected from physical damage and that conduit can be used. A bushing needs to be used where the cable goes into the conduit. The3 cable must also be secured within 12" of the point the cable enters the conduit.
Old 10-30-2009, 02:26 PM
bob smit bob smit is offline
Daniel; Please give more info such as...location, wall construction, ceiling and the like. Post a pic if u have one. Then we can respond intelligently.
Bob Smit, County Electrical Inspector
Old 10-30-2009, 02:29 PM
Scott Patterson's Avatar
I personally see no need in protecting NM cable in a unfinished basement when the cable is properly supported in the stud cavities and up along the ceiling joist bays.
Scott Patterson
Old 10-30-2009, 07:12 PM
I take "unfinished basement" as plain concrete block or concrete walls with out studs. If there are studs and the NM Cable is stapled to it then that is the protection that is needed. If its cables for receptacles / switches on the block / concrete walls then protection is needed
  #6 (permalink)
Old 11-01-2009, 04:36 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Ditto with Scott, Cables should be run through the studs in the bays. If they are outside the bays they need protected.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
Greetings... new here, Adirondacks, NY area adkjac Introductions By New Members 4 08-25-2008 08:23 AM
New to Area Christopher Tracy Introductions By New Members 3 05-10-2008 09:59 AM
Wiring inside the chimney area Mike Pearson Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 07-23-2007 10:11 AM
Insulate basement Mike Schulz Sub-Structure: Home Inspection and Commercial Inspection 3 05-04-2007 10:25 AM
Unfinished repairs 'desperate situation' - London Free Press Brian Hannigan Inspection News From Around The Net 0 04-03-2007 04:12 AM
vB.Sponsors
Ad Management by RedTyger
