Exposed Facing on Batt Insulation in Crawlspace
How do you call out exposed facing on batt insulation installed along a cripple wall in the crawlspace (paper or older foil type)? The newer type has the warning label concerning fire, the older or foil type does not. Instead of being replaced, can it just be flipped around where the facing is against the back side of the siding or shear? Will this create a moisture problem?
Interested in your thoughts.
Thanks,
Phil K.
