Old 07-30-2007, 08:58 AM
Greg Jenkins Greg Jenkins is offline
Block Pier Construction
Very often, I enter a crawl space only to see where someone has installed supporting piers in various locations to support a sagging floor structure or a poorly supported main house beam. In my area, most crawl spaces have very little head room so you know is must be very difficult to work in. Typically when I see these add on block piers (cmu's) they are dry laid and generally resting on the soil (no footer). In addition, they are usually not anchored to the floor strucutre. Typically it is a block pier with wood or metal shims. Likewise, I will often see additional beams installed to support several sagging floor joists. Again, beams, piers, and joists are not anchored together. My question is: Should one expect to see footers beneath piers, and beams and joists anchored together. Again, a lot of the spaces are very difficult to get into much less excavate an area to place a footer beneath a new pier. I am just curious as to what other people are seeing and how far to go when suggesting repairs. I am posting a few pictures as an example.
Greg Jenkins
Old 07-30-2007, 09:55 AM
John Arnold John Arnold is offline
Re: Block Pier Construction
Greg - There's no way that I, a generalist home inspector, am going to sign off on anything that looks remotely like your photos, regardless of how hard it may be to work in there, so I advise the buyer that there's non-professional and improper structural supports and a competent contractor or engineer needs to be called in.
Old 07-30-2007, 10:21 AM
Jerry McCarthy's Avatar
John is correct, report what you see then defer the condition to a qualified source. Your job has been done.
Construction Consultant
Old 07-30-2007, 06:43 PM
Rick Bunzel's Avatar
Rick Bunzel Rick Bunzel is offline
Greg,
Yours looked pretty good compared to last weeks. My redneck engineers couldn't even afford a whole cinderblock!
Rick Bunzel
WWW.PacCrestInspections.com
360-588-6956
Old 07-30-2007, 08:03 PM
Richard Rushing's Avatar
No only that, they turned them the wrong way...
RR
Richard Rushing, HCRI
Duncanville, Tx.
  #6 (permalink)
Old 07-31-2007, 06:42 AM
Thom Walker's Avatar
This was one of my favorites.
- Paul Fix
  #7 (permalink)
Old 07-31-2007, 02:03 PM
Thom,
It's easier to view photo if you just upload the photo and not make it into a pdf file.
  #8 (permalink)
Old 07-31-2007, 04:59 PM
You're retired. How easy does it have to get? Double click. Ouch! The pain!
The photo is no longer in jpeg. It's part of a WORD doc. pdf was the logical choice.
- Paul Fix
  #9 (permalink)
Old 07-31-2007, 05:39 PM
Quote:
Enough of a pain to not always look at those in pdf format.
To me, the logical choice is to click on the photo and copy it to its own file. *I* would *never* not keep my photos separate from the report. I keep my photos in their own folders by client name, and insert *copies* into the reports.
I'm retired, but I'm not a slave to opening multiple files just to see a photo. Usually I just don't bother with them.
Your choice.
  #10 (permalink)
Old 07-31-2007, 06:18 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
As much as I hate to admit it - I agree with Jerry on this one.
I single clicked the pdf file, my computer then had to open Adobe Reader to open the file, after viewing the photo, I had to close out of Reader, close another window and get back to InspectionNews. More than a couple steps.
Maybe I'm just lazy.
To the question at hand. While I see many dry stacked blocks, I always call them out as an issue. Every engineer's design for repairs has called out for a footer uder the added piers or posts.
JF
  #11 (permalink)
Old 07-31-2007, 06:56 PM
Rick Hurst's Avatar
Thom,
Why not just save your HI inspection photos in a file so you'll have them for future reference or when posting on the board here.
We save all of our photos in a file labeled with the property address along with the HI report. Save all your photos, not just the ones you put on the report.
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
  #12 (permalink)
Old 08-01-2007, 09:05 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
And now from a home built in ~1929.
Cheers - Nolan E. Kienitz, PMP
Dallas Home Inspector
www.NolansInspections.com
  #13 (permalink)
Old 08-01-2007, 09:32 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
"They sure don't build houses like they used to."
"No, sir. They won't let us."
Bruce Breedlove
www.avaloninspection.com
  #14 (permalink)
Old 08-01-2007, 10:04 PM
Rick Hurst's Avatar
Nolan,
Let me guess, the east side of McKinney.
Rick Hurst
  #15 (permalink)
Old 08-01-2007, 10:32 PM
Rick,
Nope. On Live Oak just East of North Central and not far from Swiss Avenue homes.
  #16 (permalink)
Old 08-01-2007, 10:36 PM
Rick Hurst's Avatar
Oh yes, the Historic area.
As the realtors say, Homes with Southern Charm.
Similar Threads
Void at garage block David Macy Structural Components: Home Inspection and Commercial Inspection 2 07-14-2007 12:58 PM
7 year old construction Victor DaGraca Attic Areas: Home Inspection and Commercial Inspection 10 06-17-2007 02:42 PM
block support for furnace Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 06-09-2007 11:03 AM
New Construction-- no one will notice Richard Rushing Roofing System: Home Inspection and Commercial Inspection 2 05-09-2007 09:15 PM
Concrete block wayne soper Sub-Structure: Home Inspection and Commercial Inspection 17 04-15-2007 10:31 AM
vB.Sponsors
Ad Management by RedTyger
