Re: PVC pipe terminating in crawl space
Well, they were so thoughtful that, when they installed the pipe, they push the insulation down with it. Nice.
There is a brow stain at the end of the pipe and on the plastic below it.
While I do not know 'what' it is, I do know that 'no pipe' is allowed to drain to the crawlspace.
I really like those 2x4 studs right behind it, look just jammed up against a concrete footing and another 2x4 above it ... that 2x4 above it has little strength laid flat-wise like that, and what's to keep those vertical 2x4s from moving and falling out?
