08-22-2007, 07:54 AM
FOUNDATION STAINING
Does anyone know what the brown staining on this foundation could be from. There are no metal straps or bolts near the staining. There is not any type of metal on top of the foundation or sill plate.
08-22-2007, 08:14 AM
Re: FOUNDATION STAINING
alot of things to consider. nails in pywood rusting, but why. before or after siding install. was there a window above? how old was the home. any of the same on the sideing above
08-22-2007, 08:15 AM
looks wet. did you test it?
08-22-2007, 09:50 AM
Is there a bathroom on that wall?
- Paul Fix
08-22-2007, 11:31 AM
I looked under the siding the best I could and did not see any staining or rusted nails. The foundation was wet from rain, but the staining has been there for several months. This is a new addition and the staining is on all sides of addition.
08-22-2007, 01:56 PM
I'm going to guess that there is some type of asphalt impregnated material behind the siding, it got wet during construction, and it gets wet when it rains (moisture gets behind the siding).
This is the residue running down from the asphalt product in the material.
It will likely keep getting worse.
The only way to seal back the stains is with a stain sealer made for exterior use, but, whenever it gets wet, it will run down and stain again.
08-22-2007, 02:36 PM
The addition has Tyvek and no type of asphalt paper
08-22-2007, 03:40 PM
I'd set the house upright for a few weeks, and see what happens.
Seriously, though, was that wall recently parged? If so, you may be seeing bleed through from something below the parging.
08-22-2007, 05:08 PM
A high legged dog?
08-22-2007, 05:36 PM
Would this happen to be on a wall where there is an exterior hose bib close by??
Richard Rushing, HCRI
Duncanville, Tx.
08-22-2007, 05:37 PM
Here's my WAG.
I've seen this before only because I caused it.
While treating a wall void with TIMBOR for a termite infestation, the run-off actually ran down the outside beam wall and caused such staining.
You might check with the homeowner and see if any recent termite or pest control has been done in that area of the wall.
Just a thought.
08-23-2007, 10:28 AM
i've seen pressure treated sills or plywood cause similar staining when they get wet and leach out chemicals.
08-24-2007, 05:40 AM
Thanks for all the help. Does anyone know how to get the stain off. They already tried power washing.
08-24-2007, 09:37 AM
That ole girl (the stain) is impregnated into the slab-- she's not coming off. More thatn likely a cosmetic coat (another stain) will have to be fully applied to give an even cosmetic appearance-- just not pink
Duncanville, Tx.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Tabby foundation? |
Barry Grubb |
Sub-Structure: Home Inspection and Commercial Inspection |
3 |
08-13-2007 04:24 PM |
| Foundation Questions |
Jim Dull |
Building Envelope: Home Inspection and Commercial Inspection |
7 |
06-29-2007 07:31 PM |
| Crack in foundation |
Jeff Eastman |
Structural Components: Home Inspection and Commercial Inspection |
15 |
05-22-2007 01:15 PM |
| Staining on damper |
Jeff Eastman |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
1 |
05-08-2007 08:30 AM |
| Staining on exterior wall near A/C |
Jeff Eastman |
2 |
04-08-2007 04:30 PM |
