Old 10-04-2007, 03:01 PM
Bill Wieczorek Bill Wieczorek is offline
Beam Question
Is it required that steel beams be cemented in the beam pocket or can they be set without concrete.
Home inspection
Old 10-04-2007, 03:28 PM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
Re: Beam Question
I'll guess at it in a round about way.
If the beam was supported by an engaged column instead of in a pocket, you wouldn't glance at it twice.
If it were wood it would be prohibited.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Old 10-04-2007, 03:31 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: Beam Question
Quote:
Bill,
Can you give us a little more information? Residential?Commercial? Pictures? Size?
Where they fastened by some means?
IRC 2003 only goes to 60x36 in secR505.
Billy J. Stephens HI Service
Old 10-04-2007, 03:50 PM
Re: Beam Question
A fellow inspector called me to ask so I don't have pictures. The beam 40 feet is resting in beam pockets in a residence. Its seated into the pocket by 4 inches on each endand there are 3 supporting posts. I didn't think cementing in the ends was required but I'm drawing a blank so I thought I'd ask. Oddly I looked at mine and they are cemented in, hence the question. Its heck to get old and not remember little things.
Old 10-04-2007, 03:54 PM
Re: Beam Question
Bill,
I didn't see anything in IRC 2003 that requires cemented into the pocket.
Any other takers?
  #6 (permalink)
Old 10-04-2007, 06:59 PM
Re: Beam Question
I would think that cementing them into the pocket would be more for fire protection than anything else. It certainly will not hold that beam in place should it decide it needs to move.
That would require either bolting to poured concrete or welding to an embedded plate.
If that is supporting a load above, what is holding it down (from uplift)?
  #7 (permalink)
Old 10-04-2007, 07:00 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Beam Question
Not worth pointing out. What's concrete fill going to do? The beam is not going anywhere (if it does there's much bigger concerns at issue). Not much different than loose bolts and and nuts at the beam/column connections - a none-issue with me. I've seen a lot of things in a basement/crawl that have moved over time but never, ever a beam that was properly supported. There's just too much weight on it for it to shift.
Eric Barker
Barrington, IL
  #8 (permalink)
Old 10-04-2007, 09:31 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Beam Question
One purpose of grouting (I prefer that term to "cementing") the beam end in a beam pocket is to resist rotational movement. Rotation is more of a concern when the beam is tall and narrow and less of a concern when the beam is the same width as the height.
If the beam is tall and narrow AND is very long AND does not have lateral support along its length it is more likely to rotate. Having rotational restraint(s) at the end(s) of the beam would be important in that situation. Properly placed grout will restrain the ends of the beam from rotation as the rotating beam will be placing the grout into compression against the sides of the pocket and grout, like concrete, is very good in compression (but not tension).
I don't think the fire protection provided by grouting the beam in the beam pocket makes any difference whatsoever. Assuming a simple beam (no rigid end connections), the stresses at the ends of the beam are very small compared to at mid span. If there is a fire hot enough to cause the steel beam to lose strength it will fail at mid span long before it fails at the end supports.
Bruce Breedlove
www.avaloninspection.com
  #9 (permalink)
Old 10-05-2007, 05:02 AM
Re: Beam Question
Quote:
I'm thinking more along the lines of fireblocking. Fill the beam pocket with grout and you've fireblocked that open area up into the wall (at least as I am envisioning the way it would be configured).
As far as rotation goes, I am envisioning a standard flange ("I") or wide flange ("H" on its side) beam which is not that tall, the ones I've seen did not have a large height/width aspect ratio, thus rotation would not be an issue.
Without a photo, who knows.
  #10 (permalink)
Old 10-05-2007, 05:56 AM
Re: Beam Question
Bruce,
You're referring to a wood beam (obviously). I don't like the idea of wood encased on concrete - too much moisture retention and possibility of decay.
As for cementing terminology. Cement is the mix to make concrete. Though I doubt that few would not understand cementing the pocket.
Eric Barker
Barrington, IL
  #11 (permalink)
Old 10-05-2007, 09:45 AM
Re: Beam Question
Eric,
No, I'm talking about a steel beam. I agree, grouting a wood beam is not recommended.
Not all steel beams are compact. As I said earlier, a beam that has a height much greater than its width is subject to rotation. Like Jerry , most steel beams I see do not have a high height/width ratio but on occassion I do see them. Wood beams by their nature do have a high height/width ratio.
The attached image shows how rotation occurs in a steel beam.
Bruce Breedlove
  #12 (permalink)
Old 10-05-2007, 02:35 PM
Re: Beam Question
What would make a beam twist as shown, maybe a fire perhaps.
  #13 (permalink)
Old 10-05-2007, 03:06 PM
Re: Beam Question
Bruce,
Interesting. Can't remember seeing a high profile beam in residential construction. In such a case the filling of the pocket makes sense.
Eric Barker
Barrington, IL
  #14 (permalink)
Old 10-05-2007, 03:40 PM
Re: Beam Question
Asymmetrical loading. Have you ever seen a beam where the support post was off center? That's how it starts. As the beam rotates a little the loads become more and more asymmetrical causing the beam to rotate a bit more causing the loads . . . The higher the height/width ratio the more a problem with those off center loads.
Does it ever happen? You bet it does. It is more common on tall, skinny beams.
I did the repair on a double wood lam beam that had rotated so much the bottom of the beam had moved almost 6". That beam was very deep (vertically) - maybe 14" - and was very narrow - two 2 1/2" or 3" widths - so the height/width ratio was high. There were one wall framed into the beam near the far end but there were no lateral braces along the rest of its length and the near end of the beam was free to rotate in the beam pocket.
This tall, skinny beam was balancing on a few teleposts. Try balancing a credit card on edge on the end of a pencil between your hands and squeeze. That should give you an idea of how precarious this arrangement was.
Everything is fine if the beam is perfectly aligned with the post but, as we know, this does not always happen.
Bruce Breedlove
  #15 (permalink)
Old 10-05-2007, 07:47 PM
Re: Beam Question
Another thing which will cause that rotation is overspanning a beam.
When the beam starts to deflect, it also starts to rotate, the more it deflects, the more it rotates. The more it rotates, the weaker it becomes, the more it deflects.
Self-fulfilling failure, it just becomes a matter of time.
I've also seen some, but as Bruce said, only on high height/width ratio beams. I guess that also could be because smaller beams are loaded less than tall beams, thus the loading on an overspanned beam would have less of that effect.
Similar Threads
Beam Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 9 06-23-2007 12:25 PM
beam interface with shingles John Stephenson Roofing System: Home Inspection and Commercial Inspection 13 06-22-2007 01:38 AM
Porch: Post to beam Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 4 06-03-2007 10:40 PM
Cut End on Steel I Beam Nick Ostrowski Structural Components: Home Inspection and Commercial Inspection 3 05-22-2007 11:57 AM
Nails in foundation beam Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 1 05-04-2007 03:05 PM
vB.Sponsors
Ad Management by RedTyger
