Old 04-11-2007, 03:15 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Scissor joist
This home was built in 05. The back wall in the crawl space has a knee wall and then a sill for the joist. Does the sill need strapped to the knee wall top plate?
The joist sit on the sill and has one toe nail in it. How are they suppose to be secured?
Does the joist sitting on the top plate spanned between two studs need support under it. It is a two storey home?
I appreciate any quick replies because I have to get this off first thing in the morning. Thanks in advance.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Home inspection
Old 04-11-2007, 03:22 PM
Re: Scissor joist
Opps forgot the pictures
Old 04-11-2007, 04:14 PM
Re: Scissor joist
Any chance the exterior sheathing is nailed off properly to tie everything together laterally?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 04-11-2007, 04:29 PM
Re: Scissor joist
I don't know the name of the sheathing but its those 4x8 panels that are about 1/8 thick. There water repellent. Don't remember what they are made of put are very flimsy. As far as being nailed correctly I doubt it but can't be sure.
Old 04-11-2007, 04:44 PM
Scott Patterson's Avatar
Re: Scissor joist
Got a picture of the outside of the house?
Scott Patterson
  #6 (permalink)
Old 04-11-2007, 04:51 PM
Re: Scissor joist
Here they are.
  #7 (permalink)
Old 04-11-2007, 05:26 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
Re: Scissor joist
I don't believe the joists need support directly beneath them, as there is a double top plate installed.
As far as nailing goes, I am unsure for trusess, but conventional framing is 3 8d nails toe nailed to the top plate.
  #8 (permalink)
Old 04-11-2007, 06:27 PM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is offline
Re: Scissor joist
There would not be any strapping here in my area. It has been about four years since I did any framing, but I know we wouldn't have back then. It may have changed. Then again, we're definately not in a hurricane zone, or even a high wind zone.
  #9 (permalink)
Old 04-11-2007, 08:03 PM
Re: Scissor joist
Would a single nail be sufficient for fastening?
  #10 (permalink)
Old 04-11-2007, 08:41 PM
Re: Scissor joist
You sould probably try and look up the manu. specs.
I'll bet they require one on each side of the flange, for a total of two.
Similar Threads
Joist support Francis Turak Structural Components: Home Inspection and Commercial Inspection 14 04-04-2007 06:15 PM
vB.Sponsors
Ad Management by RedTyger
