Old 12-15-2007, 07:08 PM
Chuck Edwards Chuck Edwards is offline
Stair step cracks ,no crack in foundation ,8 foot from window
I'm new to this forum and was wondering if any of you guys can help.Found stair step cracking in the morter joints,on a 2 story home 38-40 years old. The cracks are on the far right corner where a fire place chimney is present and are only on one side of the corner .The cracks ended at the window without any indication of foundation damage (at this point).I'm considering siting the possibility of foundation movement ?
Next issue is definite foundation movement with 2 hairline cracks found in 2 areas at the front of the home. The floor in the home is out of level all the way through and there is apparent movement because I found signifigant separation on the interior walls .I now that I will refer a structural engineer ,but I was looking for some input .would have sent pick but I have to resize them.Thanks in advance.
Old 12-15-2007, 07:51 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Stair step cracks ,no crack in foundation ,8 foot from window
What kind of foundation do you have there? Slab? Crawl? Basement? Reinforced concrete? Masonry?
Bruce Breedlove
www.avaloninspection.com
Old 12-16-2007, 06:48 AM
wayne soper's Avatar
Are cracks in the chimney or the foundation? They are separate entities.
Are they near the corner? Like a few feet away from where the downspouts have been draining next to the house for 40 years? Is there lateral movement? PICS PICS PICS
Old 12-16-2007, 07:44 AM
Quote:
First, welcome to this board.
Second, "definite foundation movement" does not fit in the same sentence thought as " with 2 hairline cracks", unless you are referring to two different things, i.e., "hairline cracks" do not equal "definite foundation movement".
Quote:
The floor in the home is out of level all the way through and there is apparent movement because I found significant separation on the interior walls.
As others have asked, what type of floor construction? Slab? Monolithic? Or floating slab inside stem walls?
Old 12-16-2007, 07:23 PM
Thanks for the replies I have been in appraisal school all day.The foundation is a slab on grade , the 2 cracks are in front of the home one on each side of a doorway about one foot to the left and one foot to the right of the entrance, they are separate entities.cracks are in the foundation not the chimney,no lateral movement and no gutters or downspouts.The cracks on the brick are near a corner,the cracks in the slab are in the middle of the home
  #6 (permalink)
Old 12-16-2007, 07:40 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
......I'm considering siting the possibility of foundation movement ?
The floor in the home is out of level all the way through and there is apparent movement------- because I found signifigant separation on the interior walls ..............I now that I will refer a structural engineer ,.
---The foundation is a slab on grade ,-------,the cracks in the slab are in the middle of the home
Chuck,
Are the foundation cracks in the same area as the separated interior wall?
Billy J. Stephens HI Service
  #7 (permalink)
Old 12-17-2007, 07:27 PM
Billy yes they are but the separation in the interior wall is in the middle of the home and the cracks were found in the front of the home.
  #8 (permalink)
Old 12-17-2007, 07:58 PM
Chuck,
As Bruce B. has subscribed to this thread I will defer to opinion.
Thanks for being patience and answering a bunch of questions.
  #9 (permalink)
Old 12-17-2007, 09:08 PM
Quote:
Originally Posted by Billy Stephens View Post
Chuck,
I am subscribed to this thread?
Bruce Breedlove
  #10 (permalink)
Old 12-17-2007, 09:28 PM
Quote:
Bruce,
If ya post your subscribed.( Unless you go to Thread Tools and unsubscribe to the thread)
I "m doing what I would if it were my inspection and defer to The Structural Engineer.
With wall separation as shown She's sinking.
  #11 (permalink)
Old 12-17-2007, 09:52 PM
What benefits do I get with my subscription?
Bruce Breedlove
  #12 (permalink)
Old 12-17-2007, 09:57 PM
OK,Here You Go Bruce,
  #13 (permalink)
Old 12-17-2007, 10:05 PM
That's more like it.
Bruce Breedlove
  #14 (permalink)
Old 12-17-2007, 10:35 PM
Don't Get to Big of a Head.
You still want that Rockies Cap to Fit.
Home inspection
Similar Threads
Foundation Crack Mystery Solved Bruce Breedlove Structural Components: Home Inspection and Commercial Inspection 8 10-13-2007 12:04 PM
Crack in foundation? dan orourke Structural Components: Home Inspection and Commercial Inspection 4 09-23-2007 05:19 PM
Step/Vertical cracks in brick ... NONE in foundation Nolan Kienitz Building Envelope: Home Inspection and Commercial Inspection 6 07-03-2007 12:38 PM
New construction - stair step cracks Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-02-2007 06:58 PM
Crack in foundation Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 15 05-22-2007 12:15 PM
vB.Sponsors
Ad Management by RedTyger
