Old 01-17-2008, 09:17 PM
Frank Bombardiere Frank Bombardiere is offline
Condensation problem
I have not ever seen anything like this before so I have my theories but would like some opinions. There was heavy condensation on the floor joists under only one section of the house. It was under the kitchen but there were no plumbing leaks. About a 10 sq ft area with condensation and the rest of the floor structure was dry. They had all the crawl space vents closed and there was an open access panel to the crawl space right where all the condensation was located. We had just had some warm weather followed by sharply colder weather just before the inspection which was in the morning around 1130am.
I am thinking that moisture was migrating to the open access panel during to colder night hours as it would have been colder in that area. All the vents were closed up very tightly except for the open access panel near the area with the condensation. Any thoughts?
Old 01-18-2008, 04:00 AM
Stephen Houmard's Avatar
Stephen Houmard Stephen Houmard is offline
Re: Condensation problem
Waas trhere carpet everywhere in the home except he kitchen?
Are the HVAC vents on the floor or the ceiling?
Hell, I don't know.
Sorry
Old 01-18-2008, 05:55 AM
Ceiling registers, Wood floors
Old 01-20-2008, 06:26 PM
David Samloff David Samloff is offline
Was there a heating system under the wood floors?
Anything to do with irrigation?
Old 01-21-2008, 02:33 AM
wayne soper's Avatar
Spanish maid with a large bucket of water and a mop. What material was on the kitchen floor.
  #6 (permalink)
Old 01-21-2008, 11:36 AM
Carol Perkins Carol Perkins is offline
Was there a vapor retarder on the ground in the crawl space?
  #7 (permalink)
Old 01-21-2008, 11:44 AM
Tile floor, No vapor barrier on ground, furnace inside house, ceiling ductwork.
There was insulation on the sub floor in that area, it was wet. Looked like it has gone on for a while as there was some fungus in that area only.
  #8 (permalink)
Old 01-21-2008, 11:56 AM
Jon Randolph Jon Randolph is offline
No vapor barrier on the ground, but what about the insulation below the sub floor?
If the insulation was installed with the vapor barrier to the crawl side insteas of to the conditioned side of the home, it can and will cause just what you are describing. After absorbing humidity and holding moisture for a while, the insulation usually falls to the crawl floor, but the wood will remain wet for a long time. The longer it remains wet, the more it will mold which retains even more moisture. Before you know it, you can berak chunks off of it with your bare hands.
Pictures would have been nice. I average around 100 pics/inspection. Not all of them go into my report, of course, but they are nice to have. If nothing else, to share with your friends here at InspectionNews.net
BTW, I keep all pictures in case they are needed in the future.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #9 (permalink)
Old 01-21-2008, 01:07 PM
Quote:
Jon,
That's good ... *as long as* ... you go over the photo *VERY* carefully and make sure there *IS NOTHING* in them which you missed.
About the worst thing you can do to 'prove your side of an argument' is to bring out a photo showing something which was not on the report ... right then and there *every* other photo you took will be requested so they can have 'their expert' go through the photos to find anything and everything else you missed.
BIG Oops!
  #10 (permalink)
Old 01-21-2008, 07:33 PM
The vapor barier of the insulation was properly installed. I did not have any photos that would really tell you much so I didn't bother with them. I may go back out and look at it some more if I can to try and figure it out.
  #11 (permalink)
Old 01-21-2008, 07:46 PM
Frank, it sounds like just a weather change phenomenon.
Rapid weather change that you mentioned coupled with the difference in venting in the area.
I would imagine your weather is similar to my area and rapid changes in the weather can do some strange things if you are there to see it when it happens.
My main concern, as I understand the situation you describe, would be any long term moisture problem as exhibited by damage to wood or insulation.
If it is just a transient problem, as I suspect, I will bet you could not duplicate the situation if you try.
Mr. Inspector.net, Inc.
Allen, Texas 75002
Similar Threads
Programmable thermostats and condensation problems Michael Thomas Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 12-17-2007 08:49 PM
problem? Matt Fellman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 27 06-30-2007 09:59 AM
a problem or not dan orourke Structural Components: Home Inspection and Commercial Inspection 19 06-18-2007 08:28 PM
Basement Wall Condensation Jon Randolph Building Interior: Home Inspection and Commercial Inspection 2 06-01-2007 08:21 PM
Condensation On Flue Pipe Jim Robinson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 04-29-2007 10:18 AM
vB.Sponsors
Ad Management by RedTyger
