Old 03-21-2008, 09:16 AM
David Edens David Edens is offline
Standing water around crawlspace posts
I did recommend a waterproofing contractor for a home recently because of small pockets of standing water around a couple of posts. It was moist under most of the moisture barrier. The house is on a crawlspace that is just sliightly below grade all around the perimeter. The entire grading around the house is flat. Would this likely be more serious or just a minor fix?
Old 03-21-2008, 10:17 AM
Robert Jones Robert Jones is offline
Re: Standing water around crawlspace posts
It really just depends on what is needed to remedy the situation. If the installation of a sump is required then it can be a bit costly if done correctly. Is the home near a river? In some areas the water tables are just higher than others and can cause periodic water entrance into the crawl space. Was it musty smelling or moldy? heavy staining on the crawl space walls or wood surfaces? Is this house located at the bottom of a hill(runoff)? Here in the NW, this is very common. And it really depends on each circumstance as to what approach to take.
Rob Jones
ASHI member #212199
Washington State Structural Pest Inspector(SPI) 64730
Old 03-21-2008, 03:45 PM
Chuck Bolner Chuck Bolner is offline
As long as there is no staining on the interior concrete surfaces of the stem walls or on the wood structural members, and the moisture is contained for the most part under the vapor barrier, then the problem is of a minor nature. I would write it up as maintenance recommended or monitor this item, and recommend a periodic inspection by the homeowner. If the moisture is contained under the barrier, then the barrier is doing its job.
Additionally, the areas around the crawl space posts could be sealed to keep the water from wicking up from below. That is the easiest fix. Additional vents could be cut in also, given there is enough space and it is convenient to do so. This would help to keep air flow under the house to a maximum and help dry out any water that reaches the surface of the vapor barrier.
I find this situation a lot here in Northern California.
Chuck
Old 03-21-2008, 04:05 PM
Rick Hurst's Avatar
Chuck
Chuck,
Do you honestly think that a homeowner is going to "monitor" this condition? Not going to happen.
If there is water standing under the home, it is not a "minor" condition. The term "minor" has no place in a Home Inspection report. It will come back to haunt you one day when your sitting there in that miserable coat and tie in front of a lawyer explaining what the difference is between minor and major.
The original post by David stated that the soil around the foundation is flat. Here lies the problem. If the soil around the foundation does not have a positive slope to drain the water away, all the monitoring in the world is not going to solve the problem.
Sounds like they need to correct the grading issue around the foundation.
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
Old 03-21-2008, 04:36 PM
Jerry McCarthy's Avatar
I fully agree with Rick on this and my experience in litigation issues with home inspectors has been around 90% about moisture infiltration into the building envelope. Your client needs a state licensed drainage contractor or even soils engineer for evaluation and provide recommendations for corrective work. Water under a home is not a good thing...think M___!
Construction Consultant
Similar Threads
standing water in window tracks Ron Bishop Building Envelope: Home Inspection and Commercial Inspection 8 02-02-2008 04:58 AM
air handler in crawlspace wes owens Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 06-19-2007 07:54 AM
Crawlspace vent fan Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 05-18-2007 08:13 PM
PVC water supply lines in crawlspace Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 3 04-15-2007 08:56 AM
4,994 Archived Foundation, Crawlspace Posts Brian Hannigan Sub-Structure: Home Inspection and Commercial Inspection 0 03-21-2007 12:38 AM
vB.Sponsors
Ad Management by RedTyger
