Old 05-07-2008, 07:10 AM
CHARLIE VAN FLEET's Avatar
CHARLIE VAN FLEET CHARLIE VAN FLEET is offline
CRAWL SPACE SUPPORT COLUMNS
1990 home----three support columns in crawlspace all look just like this picture---is it code to have these columns attached top and bottom--or just recommended-----i wrote it up to have evaluated by licenced competent structural engineer
charlie
Old 05-07-2008, 08:02 AM
Ron Bibler Ron Bibler is offline
Re: CRAWL SPACE SUPPORT COLUMNS
That should have some PT under that and attached top and bottom.
Charlie That look like a steel beam on top and that is one big concrete pad.
What is the need for the steel beam and that big of a concrete pad ?
looking at that photo. looks like that 2x4 is not doing anything.
Best
Ron
Old 05-07-2008, 08:17 AM
Dom D'Agostino Dom D'Agostino is offline
Tha 2x isn't holding much, it may have been used to prop the I-beam during installation.
Old 05-07-2008, 08:19 AM
Richard Rushing's Avatar
Charlie,
Doesen't matter anyway... won't be there that long-- No termite shields and not treated material. Buggers will chem'em up like they did the with the beam lying on the ground.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-07-2008, 09:20 AM
ron that is main i beam for house--and i guess they had alot of concrete
richard----we don't have many termites here in colorado----so they dont usual treat the wood---but i usually see steel piers or jacked steel in crawl spaces----guess i'll let the structural guy decide
charlie
  #6 (permalink)
Old 05-07-2008, 09:24 AM
Vern Heiler's Avatar
Vern Heiler Vern Heiler is offline
At's a real nice dryer vent!
  #7 (permalink)
Old 05-07-2008, 10:48 AM
Jerry McCarthy's Avatar
Nothing wrong with that as the weight of the I beam will hold that support 2x4 in place and gas piping has been approved to support duct work of ANY KIND!
Construction Consultant
  #8 (permalink)
Old 05-07-2008, 11:34 AM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Dryer duct appears to be Unlisted and is connected or sealed with an Unlisted material.
Billy J. Stephens HI Service
  #9 (permalink)
Old 05-07-2008, 01:01 PM
Brandon Chew Brandon Chew is offline
Quote:
charlie
2006 IRC §RR407 COLUMNS
§RR407.1 Wood column protection. Wood columns shall be protected against decay as set forth in §RR319.
§RR407.2 Steel column protection. All surfaces (inside and outside) of steel columns shall be given a shop coat of rust-inhibitive paint, except for corrosion-resistant steel and steel treated with coatings to provide corrosion resistance.
§RR407.3 Structural requirements. The columns shall be restrained to prevent lateral displacement at the bottom end. Wood columns shall not be less in nominal size than 4 inches by 4 inches (102 mm by 102 mm) and steel columns shall not be less than 3-inch-diameter (76 mm) standard pipe or equivalent.
EXCEPTION: In Seismic Design Categories A, B and C columns no more than 48 inches (1219 mm) in height on a pier or footing are exempt from the bottom end lateral displacement requirement within underfloor areas enclosed by a continuous foundation.
  #10 (permalink)
Old 05-07-2008, 05:25 PM
Steve Frederickson Steve Frederickson is offline
I've seen many cases where a column/post that was not connected to the beam at the top and not anchored to the footing ended lying up on the ground at some point (due to loads being reduced on the beam and the beam deflection therefore being reduced, due to changes in moisture content and resulting shrinkage of the post, shrinkage of a dimensional lumber beam etc.)
Similar Threads
Crawl Space Foundation Erol Kartal Sub-Structure: Home Inspection and Commercial Inspection 6 10-15-2007 09:38 AM
PVC pipe terminating in crawl space Trent Tarter Sub-Structure: Home Inspection and Commercial Inspection 4 10-15-2007 07:34 AM
Crawl space questions? M Kelekci Structural Components: Home Inspection and Commercial Inspection 25 08-02-2007 06:49 AM
Combustion Air in Crawl Space David Samloff Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 18 07-27-2007 08:44 PM
Enclosed Crawl space ? Jim Holl Sub-Structure: Home Inspection and Commercial Inspection 4 04-12-2007 11:36 PM
vB.Sponsors
Ad Management by RedTyger
