Re: Foiled Paper in crawl space
They may have been attempting a radiant barrier with the foil, but it should be installed against the floor, not at the bottom of the joists.
The center island MAY be required to have an outlet installed at it, depending on when it was installed. Regardless of whether it is required or not, one should be installed and it needs to be GFCI protected.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
