Old 06-20-2008, 07:23 AM
CHARLIE VAN FLEET's Avatar
CHARLIE VAN FLEET CHARLIE VAN FLEET is offline
main balancing beam
did this house yesterday------have never seen this type of balancing beams before----ninety degree turn with one beam ontop of another--and then the second photo is beam in crawl space---anyone seen this before and does it look ok
thanks
charlie
no grammar corrections please--i am what i am
Home inspection
Old 06-20-2008, 08:20 AM
Michael Thomas's Avatar
Re: main balancing beam
A closer look:
Old 06-20-2008, 09:20 AM
not sure-----what you mean by------balancing beam-----you mean where one beam is bearing on another-----all depends on the bearing-------and it attachment-------however-------that one beam does look to be balancing on the other beam
(extending you the same courtesy you are extending us)
(no comments back please)
Cary Seidner's Avatar
Cary Seidner Cary Seidner is offline
Are both beams steel? In Michael's enlarged photo it looks like the top one is wood. Structurally it looks fine, but I can't tell what the connections between the post/beam/beam are like. Is there something there that will keep the top beam (and bottom for that matter) from twisting, like the 45 degree brace in the 2nd photo?
Old 06-20-2008, 09:44 AM
Nick Ostrowski Nick Ostrowski is offline
I've got a call in to Mary Lou Retton. She's the expert I refer to when I have questions about balancing beams.
  #6 (permalink)
Old 06-20-2008, 10:12 AM
Rick Sabatino Rick Sabatino is offline
From what I can make out it looks like wood between the two beams. This could compress. I wonder why they would not have used a larger beam or a steel spacer if it needed to be raised.
Rick Sabatino
Sabatino Consulting, Inc.
Oak Park, IL
  #7 (permalink)
Old 06-20-2008, 11:34 AM
brian schmitt brian schmitt is offline
charlie,
steel beams and steel structural components make the situation fall directly out of the bounds of conventional construction provisions. an engineer should be recommended to analyze the situation if you are concerned. any opinions otherwise aren't worth spit and i don't sweat speling eather
  #8 (permalink)
Old 06-20-2008, 11:49 AM
your so funny jerry
that is a steel shim between the beams and they are attached,,i just have not seen this before----again it passed construction inspection,but we all know what that means $$$$$
charlie
  #9 (permalink)
Old 06-20-2008, 02:49 PM
Quote:
Originally Posted by CHARLIE VAN FLEET View Post
your so funny jerry
charlie----not intended to be funny-----intended to be serious
  #10 (permalink)
Old 06-20-2008, 03:02 PM
about what jerry
  #11 (permalink)
Old 06-20-2008, 04:42 PM
Who's on first?
  #12 (permalink)
Old 06-20-2008, 04:45 PM
Quote:
Originally Posted by Nick Ostrowski View Post
Who's on first?
Charlie was, his thread.
  #13 (permalink)
Old 06-20-2008, 05:14 PM
so silly,can't we all just be helpful and not mock or correct the way we write or communicate, and just read the thread and help. Jerry you are so helpful in what we ask---just leave the grammar class out and stay to helping--my IAM WHAT I AM --was humor--can't correct my computer writing --does that make me a bad contributor, i don't think so-please lighten up
thanks
charlie
  #14 (permalink)
Old 06-20-2008, 05:23 PM
charlie,
not mocking you, just showing you why, when you ask questions you just do so in a way which is considerate of those you are asking------otherwise you should expect a reply of the same kind----and not complain about it
everyone else seems to be able to-----write in complete sentences and get their point across----I yam what I yam----thats popeye the sailor man
Charlie,
I really do not see what you are complaining about.
You chose - yes, chose - to not communicate in a manner considerate of others and in which it is easier to understand ... i.e., in complete sentences.
By that choice, you are in no position to complain about the context or content of the answers.
You expect more consideration than you are willing to put forth? Why? Now THAT is really funny.
  #15 (permalink)
Old 06-20-2008, 08:28 PM
jerry
this has gone far beyond what my opening thread intended---everyone states their questions and help on this web differently--
i have posted many good threads and maybe you all should get use to ones writings.LIKE MINE and accept them or ignore the non professional author type writings--- and just get read the guts of the request
the opening thread here asked for thoughts from others and jokingly said please don't correct my grammar, i have made it this far successfully in life, thirty one years at AT&T, and now sucessfully in the HI industry.dotting my i and crossing my t's the way i know how ,so give me some slack. everyone
i haved tried to be a contributing addition to this web-but my writtings are critizised by lack of comma"s and capital letters-and it makes someone want to sit back and not contribute because he doesn't cross his t's correctly or the way others want him to--is that more important then the questions and context of his threads.
you are very knowledgeable in many areas and your input is very important to me --don't care about what others think, but let me write the way i can best express myself, and read what i have to say instead of correcting how i say it.
thank you for your respect and input
lets move on and help each other OK
CHARLIE
  #16 (permalink)
Old 06-20-2008, 08:38 PM
Charlie,
Your writing style on the board does not bother me. I sometimes write on these boards in a more casual way too. Kinda like the way I speak. Keep it up! Contribute! Don't be discouraged by the critics. I've seen a whole lot worse.
  #17 (permalink)
Old 06-22-2008, 06:10 PM
Steve Frederickson Steve Frederickson is offline
Charlie, don't lose heart. I don't know why all of the fuss. I didn't think twice about writing style when I read your post. You're question was legible, which is all I ask.
Back to the point, I'm a P.E. and I've never heard of a balancing beam. The photos aren't enough to tell what's going on, but it looks like you have two beams at 90 degrees to each other, over a steel post. This is usually done when the floor framing that the beams support spans in different directions and/or there's a change in floor elevations. My only comments, based on what I can tell from the photos, are that there are no web stiffeners (not necessarily a problem; residential loads are usually relatively light) and it doesn't appear that there are any mechanical connections (beam to beam or beam to post).
As a home inspector, you should probably just note that you have some questions and possibly recommend a P.E. to evaluate. This might be overkill, though, if the house is older and there are no signs of movement (wall cracks, etc.).
  #18 (permalink)
Old 06-26-2008, 09:28 PM
Ken Bates Ken Bates is offline
Dear Charlie,
A picture is rarely worth a thousand words. Words can hurt as you have expressed.
Putting all that aside, I can say that the execution of whatever the hell it is looks very impressive.
And if the work is in fact as impressive as it appears then you have little to fear vis a vis E&O claims.
I have encountered some high tech construction that you won't find "show and tells" about in the JLC or text books, etc. and after a limited amount of studying came to the conclusion that all is well. Your risk of derision, repudiation, and other forms of humiliation ( and legal action leading to serious monetary damage ) is much greater if you call into question something that appears to be professionally and exquisitely engineered as opposed to demurring that it is probably all right; but you can say to your client, <if you want further assurances and don't mind spending money go ahead and get a second opinion.> ( Better to keep your mouth shut and be suspected of being a fool, than to open it and leave no doubt --Samuel Clemmens )
Last edited by Ken Bates : 06-26-2008 at 09:51 PM. Reason: Correction of minor spelling error. later a grammatical error
  #19 (permalink)
Old 06-27-2008, 06:00 PM
daniel nantell daniel nantell is offline
In the one photo it shows the I beam being blocked in place with a diagonal 2x4,, is this acceptable as i saw one the other day without any bracing, resting on the end corner of the foundation wall. thanks
dmn
