Originally Posted by
Mike Schulz
The basement is considered a habitable area. Now the masonry walls are not insulated and where furred and Sheetrock nailed to them. Since these walls are not below ground surface should they be insulated?
Yes, and the wall in the ground should also be insulated.
Mike Schulz
The basement is a open room except for a bathroom. It is 500 sq. There is only one register for heat source. None in the bathroom. Shouldn't there be 2 registers in the large room and one in the bath?
No requirements for that. The number of supplies depends on the size of the supplies and the air needed to heat and cool the area. Bathrooms do not required heating or cooling as bathrooms are not "habitable space".
You have a window, so you might meet the 8% of the floor area for natural light and 4% of the floor area for natural ventilation.
Is there a closet in there? Could that (would that likely) be used for a bedroom? If so, does the window meet the EERO minimum sizes?
