Old 08-26-2008, 04:26 PM
Trent Tarter Trent Tarter is offline
Plumbing pipes routed below footing
The home I inspected yesterday was built in 2001 and has the plumbing supply and drain pipes routed below the foundation footing. I know that there are better ways of doing this, however I am wanting to know if this is typically allowed by code or considered accetable.
Old 08-26-2008, 05:31 PM
Re: Plumbing pipes routed below footing
Quote:
is typically allowed by code or considered acceptable.
Yes, with the condition that a relieving arch be designed and built into the footing. That relieving arch transfers the loads imposed above the plumbing to the footings one each side of the plumbing, placing no load on the plumbing piping.
It is a requirement - though it is seldom done unless pointed out by someone who knows.
We had quite a discussion regarding this several months ago.
Similar Threads
Main Waste under footing? John Thompson Plumbing System: Home Inspection and Commercial Inspection 24 08-04-2008 08:55 AM
CSST Line Routed Through Garage Nick Ostrowski Plumbing System: Home Inspection and Commercial Inspection 2 07-30-2008 03:52 PM
Paper cover of poured footing Ross Neag Exterior Systems: Home Inspection and Commercial Inspection 15 03-09-2008 03:09 PM
Large rock under footing? Jim McClendon Sub-Structure: Home Inspection and Commercial Inspection 6 02-11-2008 08:51 PM
Plumbing vent routed over beam in attic. Eric Shuman Plumbing System: Home Inspection and Commercial Inspection 8 05-07-2007 11:25 PM
vB.Sponsors
Ad Management by RedTyger
