Results 1 to 19 of 19
01-08-2014, 06:44 PM #1
Help me decide on a homeowner Thermal Imager
Thanks for looking at this thread. (I have been a member for over three years and mostly read here)
First, I am not a Home Inspector, but am in the market for a Thermal Imager.
From looking around, it seems like I will be setting my budget at or around $1000.
My uses will be at home and the newly acquired rental house.
Here are my wants, needs and desires.
I want a unit with fairly good accuracy or differentiation, fairly good resolution and a reasonable response time. Video is not a requirement. Static Images would be nice.
The primary use will be to determine where I am leaking cold air, and what walls might be the worst exterior walls in terms of insulation (floors and ceiling also).
While I may not recoup the cost by energy savings, this is not a big concern. I will probably put this in the family loaner pool of tools and equipment.
Glenn Cummings
Eatonville, WA.
01-08-2014, 09:27 PM #2
Re: Help me decide on a homeowner Thermal Imager
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
01-09-2014, 06:41 AM #3
Ebay...
Buy a lightly used imager, as your budget really doesn't allow much in the way of resolution. Shoot for 120x120 or thereabouts, else the image will be blocky and vague.
01-09-2014, 09:23 AM #4
01-09-2014, 04:45 PM #5
New Tech! - The Inspector's Journal Forums
A new iPhone attachment by Flir for about $350. Check it out.
Not good enough for work, but a fun device for a home owner, IMO.
01-09-2014, 07:10 PM #6
01-09-2014, 08:09 PM #7
01-10-2014, 10:59 PM #8
01-11-2014, 04:36 AM #9
common sense
hire a pro or rent an imager if you feel qualified...use the savings/difference to retrofit/repair/replace what's found
you may not know, what you don't know
absence of thermography fundamentals, building science knowledge & misinterpretation of images is not uncommon amongst the "certified wand wavers" in our industry
01-11-2014, 08:55 AM #10
01-11-2014, 08:31 PM #11
01-11-2014, 09:16 PM #12
I'm with Marc on the E4 recommendation... good bang for buck and fits the bill for a non-pro or at least someone *not* doing Building Envelope IR.
FYI Hands On Review: FLIR ONE iPhone Infrared Camera | Ivy Tools Blog
I'm guessing that these devices will be doing all sorts of things they should and shouldn't do. Who knows.
From the reviewer...
Maybe Flir will place a "non-professional use" sticker on the box... ya think?In the same way that the iPhone digital camera has not replaced the SLR digital camera, the FLIR ONE is not going to replace the FLIR thermal cameras used by professionals the world over. Like the iPhone, the FLIR ONE has no focus operation–nor is one necessary in most conditions. The FLIR ONE will also not be the camera of choice for those who need to see fine thermal detail, view images at a long distance, or make very accurate temperature measurements. But using the same SLR analogy, the FLIR ONE is positively the first available “point and shoot” thermal imager.
01-11-2014, 09:36 PM #13
" the FLIR ONE is positively the first available “point and shoot” thermal imager"
Guess that reviewer is either too young to remember or is not much of a reviewer - when I bought my infrared camera 10 years ago, Infrared Solutions at the time - Fluke bought out their infrared camera operations, my camera was fully automatic and was, indeed, 'point and shoot'.
And, even being fully automatic, it beat the quality of the FLIR cameras of the day with a much higher resolution, even the FLIR cameras which cost 3 times more than that one (which was $13,000 then). The FLIR cameras with their adjustability were, no doubt, more versatile than my camera was, but all that adjustability was a negative for my uses (I was not going into to commercial/industrial/substation electrical installations and performing thermal imaging of the electrical switch gear).
I would love to have an infrared camera like my old one, it would make a great tool for what I still do.
01-13-2014, 04:17 AM #14
01-13-2014, 04:29 AM #15
Hire a professional thermographer. Don't waste your money on a complicated piece of equipment.
If you suspected you had cancer and could get an MRI for $50, would you interpret the images yourself?
www.dapkusinspections.com
www.chicagoinfraredthermalimaging.com
Infraspection Institute Certified Level III Thermographer # 8510
01-13-2014, 05:33 AM #16
01-13-2014, 10:30 AM #17
Here are some possibilities.
Shop thermal imager online Gallery - Buy thermal imager for unbeatable low prices on AliExpress.com
01-23-2014, 11:15 AM #18
Sorry, I reject the argument as a non-sequitur.
As a home-owner for years, managing rental property and my intended uses, we are not really talking about complicated equipment.
Since I am not as fast as I used to be, owning equipment for me is cheaper than hiring or renting.
I am capable of self-study, learning and gaining experiencing and can seek help where needed.
For me, using the imager, addressing the problem and re-imaging in my own time is a preferred method. It also allows me to add to the family loan pool of tools, equipments and services.
Please note, that If I had an MRI, you can be sure that I would look at them.
I rebuild engines, reload ammuntion, build fire-arms, was a leading aero-space senior systems architect, run tractors on the farm, inject immunizations, cook, tie flies, fish, pay too much taxes, and support the constitution.
A little imager does not intimidate me. God has blessed me with aptitude.
Glenn Cummings
Eatonville, WA.
01-24-2014, 06:26 AM #19
Glen,
Stop by a Home Depot rental center (check online for which has IR cameras to rent) where you can rent an Flir ix series camera for $45/4hr or $75/24hr. Rental may be your best path. At least you can see if you have a real valid long term use or just a one or two time project need.
