Results 1 to 15 of 15
Thread: Ode to an Old Friend
06-28-2009, 01:26 PM #1
My Raytek Raynger ST2 finally bit the dust after 9 years of daily service.
Any suggestions on what to buy now?
06-28-2009, 01:27 PM #2
Re: Ode to an Old Friend
I guess I should have said this is an infrared thermometer.
06-28-2009, 01:32 PM #3
Does anyone have experience with the Extech Mini Infrared Thermometer?
06-28-2009, 01:33 PM #4
Fluke 63 Infrared Thermometer
-25 to 999°F, 12:1 (D:S), ±1% accuracy, laser sight, fixed emissivity (.95), hard case
Pretty much the same, maybe better specs to what you had. I have had it for a while and am happy with it
06-28-2009, 01:56 PM #5
At 6:1 ratio you need to be really concerned with how close (how far away from) you are to what you are measuring.
At 6 feet away you are measuring a 1 foot diameter circle, and that is HUGE.
Ted's reference to one with 12:1 is twice as accurate, at 6 feet you are measuring a 6 inch diameter circle.
The one I use is 33:1, so at 6 feet I am measuring about a 2 inch diameter circle.
They make 50:1 ratio ones now (mine is probably about 10-15 years old), maybe even better ratios than that.
06-28-2009, 02:11 PM #6
Yes but you have that never ending sticker on the side for the distance acuacey and mine only cost in the mid 2s not in the mid 7s or 8s. I would rather do a quick distance check and check or refresh my memoryy of what I may have to subtract instead of paying 2 to 3 times as much. Most of the time you are pretty close where it does not make a difference.
06-28-2009, 02:17 PM #7
Ted,
I don't have a distance measuring one, too old for that, just the laser pointer for the target.
I paid $545 for mine back then.
06-28-2009, 02:31 PM #8
06-28-2009, 02:44 PM #9
06-29-2009, 06:33 AM #10
Thanks to all, except of course RB, who just could not let an opportunity to sell, sell, sell that IR camera crap pass.
06-29-2009, 08:51 AM #11
I opted for the Raytek Raynger ST-20XB. It is discontinued and being replaced by Ted's Fluke 63. Same capabilities. $119 at Amazon.
By the way RB, isn't the Extech that JL is dissing made by FLIR, the high and mighty maker of all things Cracker Jack?
06-29-2009, 09:07 AM #12
06-29-2009, 09:31 AM #13
06-29-2009, 09:50 AM #14
06-29-2009, 10:00 AM #15
