Results 1 to 3 of 3
Thread: Tramex meter keeps beeping
09-08-2009, 05:48 AM #1
My Tramex Moisture Encounter Plus meter sometimes won't stop beeping after I pull it away from the material being tested. The only way I can get it to stop is to disconnect the battery. When I re-connect the battery it works normally again.
Anyone else have this problem?
I just emailed Tramex about it.
09-08-2009, 06:54 AM #2
Re: Tramex meter keeps beeping
09-08-2009, 09:03 AM #3
Did you try Banging it with a Knocking stick... Sometimes that helps...
When was the last time you sent it off for recalibration ?
Best
Ron
