Results 1 to 10 of 10
Thread: Short range proximity locator
10-16-2009, 09:57 PM #1
I'm looking for a tool that probably exists, but which I've never seen advertised: a short range RF locator.
What I'm envisioning is a small (cigarette lighter sized) battery powered RF transmitter and a small battery powered directional receiver - sort of like the locator heads for sewer cams, but with a shorter range (say, 3 feet through non-metallic building materials).
For example, you would place the transmitter at the ceiling below an attc or at the underside of roof sheathing, and them locate its position from the attic or roof top.
Does this tool exist?
Similar Threads:Last edited by Michael Thomas; 10-16-2009 at 10:28 PM.
10-17-2009, 04:03 AM #2
Re: Short range proximity locator
Is this something you think might work?
Tempo 701K Classic Tone & Probe Kit
10-17-2009, 05:35 AM #3
To find location of a leak observed in the attic I use a magnet held in place by a long nail just started into the underside of the sheathing. Then use an old magnet type stud finder to locate it from the roof side. Not rocket science but it works.
10-17-2009, 06:47 AM #4
10-17-2009, 06:50 AM #5
Hummm... perhaps.... for example you could clip it onto a roofing nail... or perhaps it would even work by itself, depends on its detection range.... I have a similar device I bought to tone out the CAT 5 in my house, but you have to get within an inch or two of the wire..... I was thinking of somethign that would detect the signal when you got to within a few feet, and then guide you to the transmitter
10-17-2009, 07:33 AM #6
Michael
I have one like that, and use it often.
It has a range of up to 3 or 4 feet and gets louder the closer you get to the transmitter.
10-17-2009, 02:16 PM #7
10-17-2009, 02:24 PM #8
Duh.... turns out want I want is a "key locater" Products - Loc8tor - Don't lose it, locate it!
10-17-2009, 08:16 PM #9
The locators have a great range for "Line of sight." No mention in the ads if they work through any type of material. Let us know if they do please.
10-18-2009, 01:13 PM #10
Michael
Yes it will work through walls,floors,brick, etc..
And that is the same one I have.
