Results 1 to 21 of 21
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Multi-Meter Suggestions
    My electrical multi-meter headed south today. Any suggestions for a good unit that won't break the bank, i.e. <$300?
    Default Re: Multi-Meter Suggestions
    AD,
    Depends on what you are looking for. You can get a standard digital multimeter for $50 - $75 at Radio Shack. Been using mine for several years now. Fluke makes a nice selection of multimeters with clamp-on ammeters. Check out the tool retailers at the left sidebar of Brian's site here.
    A.D. Miller Guest
    A.D. Miller Guest
    TM: Will it still work east of the Trinity?
    Yes.....and even East of Dallas County. Maybe all the way to the right coast.
    Which one?
    Well, since you are paying for it and I would want you to have the best, then you should purchase the most expensive.
    I would think that any of them would do what a home inspector would need it to do. An expensive one won't provide you any features that you are likely to use. I would choose the most affordable.
    A.D. Miller Guest
    GA: You are too kind.
    Nov 2009
    St Paul, MN
    I hate to admit it but I've had really good luck with the Cen-Tech stuff from Harbor Freight.
    Harbor Freight Tools
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    I hate to admit it but I've had really good luck with the Cen-Tech stuff from Harbor Freight. Harbor Freight Tools
    Who let this guy in?
    Sep 2007
    Fredericksburg, VA
    From my not too far past electronics days, I always used Fluke when possible. Not cheap but I always found their equipment to be dependable and accurate. They are also pretty good with maintaining availibility. But for home inspection work where 1% or better accuracy, in my opinion, isn't necessary, I look more at test leads. I don't want cheap leads that are stiff even in warm conditions. They kink and hold folds that hang up on most anything.
    Stu, Fredericksburg VA
    daniel nantell's Avatar
    daniel nantell Guest
    go to ebay you won't have to buy it you can steal it.
    A.D. Miller Guest
    You guys have given me a list that runs the gamut between what comes for free in a Cracker Jack box to something every Ferrari owner should carry. Can I get a consensus on a moderately-priced, decent unit?
    chris mcintyre's Avatar
    chris mcintyre Guest
    Can I get a consensus.........
    Has this ever been the case for any thread ?
    A.D. Miller Guest
    CM: No, but it never hurts to ask.
    Cat IV rated to 600 volts, good.
    Cat III rated to 600 volts, okay, but not as good as the others.
    Cat III rated to 1000 volts and Cat IV rated to 600 volts, better (most HI work would be Cat III).
    No Category rating shown, but at that price it likely is at least a Cat III - but needs to be verified first.
    Does not give its Category voltage rating - would not consider without knowing it is at least a Cat III or IV rated (Cat III MINIMUM for the typical home inspector use, with Cat IV being better for protecting your life).
    Multimeter categories: Multimeter Safety
    http://www-group.slac.stanford.edu/e...ter_Safety.pdf
    CAT IV safety rating on new digital multimeters: News from Fluke (UK)
    A.D. Miller Guest
    JP: Now that's what I'm talking about. Thanks.
    Chicago IL
    AD check out Fieldpiece Instruments. They make a few different multi-meter units. The meters have nice features and have been working good for a few years now. What's even better are all the attachment heads you can buy. The various heads come in extremely handy.
    www.aic-chicago.com
    Richard Soundy's Avatar
    Richard Soundy Guest
    Oh Boy!
    I will soon be known as "Mr Frugal"
    I recommend and use the ~$18.00 Simpson analogue meter - In the HI industry I assure you you will get far more meaningful results from your measurement - yes, you have to switch ranges and types of measurement, but it is a sure detector of "ground loops" - the digital types are far way to fast and sophisticated, which in turn miss some important measurements that can still be detected with the "slow" analogue type measurements.
    regards - richard
    Vancouver - Canada
    You're not there testing or trouble-shooting sophisticated electronics so you don't really need anything more than a cheap multimeter that'll give you volts and maybe ohms. Unless you want to spring for one of those circuit analyzer / tracer devices but at that point, you're going well beyond the call of duty.
    Joe Klampfer RHI
    www.myinspection.ca
    Pacific Home Inspections
    A.D. Miller Guest
    For you, Aaron, I would recommend one of the Fluke 170 series, preferably a low serial number.
    FK: You mean like 79000000 and below?
