12-12-2010, 10:41 PM #1
yone using the Extech M210 pocket moisture meter?
If you have this, can you explain the scale when the meter is in "building material" mode? 0 - 2.4?
Similar Threads:Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
12-13-2010, 09:50 AM #2
Re: yone using the Extech M210 pocket moisture meter?
maybe you should check the manuel or check with the manufacture and see if they can send you an operational manuel. that would save you next time when you have a problem with readings.
12-13-2010, 10:10 AM #3
User Manual available to download at: http://www.testequipmentdepot.com/ex...dity/mo100.htm
Stu, Fredericksburg VA
12-13-2010, 08:24 PM #4
Did that...i'm looking for someone who can explain what is the reason the moisture level only goes to 2.4 not 100%
