Results 1 to 25 of 25
02-28-2016, 05:20 PM #1
2016 Digital Cameras - Rugged/Water Resistant
OK Folks,
I've not seen any posts about cameras in a while. I have a Panasonic Lumix DSC-TS20. It's been great but it's 3.5 years old and getting long in the tooth so I'm toying with the idea of separating myself from some cash.
If you bought a rugged camera last year or this year, give me your pros and cons.
I particularly like the small point/shoot, rugged/water resistant ones because I can wash them off after crawling around under a house.
Thx, Bruce
Similar Threads:Bruce Thompson, Lic. #9199
www.TylerHomeInspector.com
02-28-2016, 07:50 PM #2
Re: 2016 Digital Cameras - Rugged/Water Resistant
Olympus and Nikon make the two best. They are pretty much the same when you compare them side by side.
Olympus TG 870 and the Nikon AW 130 are the ones you need to look at. Olympus TG 860 is still available and will be about $30 to $50 less from what I have seen over the TG870 which just came onto the market. I'm going to pick up the new Nikon simply because I have an older AW100 and have had no problems. I just need the WiFi on the new model for my Eye Stick pole.
02-28-2016, 07:57 PM #3
I love Panasonic Lumix cameras, and have owned a dozen. You are very lucky to have one last that long. Every one of mine eventually failed with the zoom feature. Panasonic probably has the worst customer service/warranty/repair relations than any other company I have ever dealt with. One time they lost my camera (sent in for repair) for over 4 months. Mine usually have the zoom go out, and/or dirt gets inside and leaves spots on the photos I shoot.
While I still own a couple Panasonics, I now use a Fuji XP waterproof and rustproof camera. It lacks the zoom the Panasonic does, but I don't have to worry about dirty conditions.
02-28-2016, 08:56 PM #4
Jack, have you used the Lumix rugged series? Or were your dozen, non-water resistant? Mine has a digital zoom as opposed to an optical zoom. For me, it's fine. The reason I ask is that a friend just bought the Fuji XP and it's very similar to the Lumix I have. I've been contemplating it because he just bought it last Thursday for $125 at Walmart.
Scott, I just bought a selfie stick for some high shots and am having to use the self-timer feature. Does an eye stick pole allow you to press the button remotely?
02-29-2016, 05:05 AM #5
No, mine were the regular Lumix cameras. Loved the 20X zoom.
02-29-2016, 08:07 AM #6
My first camera, a Lumis DMC-FX 200 was wonderful.
I got it half price at Sears. Lasted 2 years then the flash went. Still have it.
Now I am using a 2 crossover cameras.
HX300 Camera with 50x Optical Zoom.
Very rugged.
I ran over the entire camera with my truck. Opps.
Still worked but again no flash. Ahhh!
Bought another one right away.
I am hard on my tools as you can see!
You can get really close to an object.
Camera with 50x Optical Zoom & 720p Movies | DSC-HX300 | Sony US
$325.00 in Canada.
I bet its under $250.00 in the land of the free, or so they say.
Never know, it might be free.
02-29-2016, 07:15 PM #7
02-29-2016, 07:35 PM #8
03-01-2016, 05:36 AM #9
I am with JB.
Can you explain the pro's and con's behind telescoping camera poles please Scot.
They start around $800.00 and you can not lift the first shingle to see the starter and underlay nor see behind boxes, and roof venting or mid or centre mounted chimneys.
Thanks.
03-01-2016, 12:34 PM #10
I paid I think $500 without a camera for the EyeStick, delivered to my doorstep. I would say that around 75% of the homes I inspect have roof slopes of 8/12 and better. So getting on to those steep pitch roofs is not going to happen and I do not want to mess with a drone. I have only had the pole for few weeks but it has been easy to use and also my clients like the idea of it. It has a good Wow factor!
Sure it has limitations just as anything does including me! My limitation of not getting on steep pitch roofs is made a little easier with this pole. It is really handy at viewing prefab metal chimneys with those metal caps the rust out after about 20 years! I even used it the other day to poke into an attic space that I could not access due to a small scuttle hole. I discovered K&T wiring in that attic with Romex spliced in and going down the wall with the pole and camera.
It is just another tool just as my IR camera.
03-01-2016, 01:16 PM #11
Not that this relates to what the question is, but it relates to Roberts statement above ... which, with a good cross-wind, leads to 'thread drift' ...
My first digital camera was a Sony Digital Mavica MVC-FD5 in 1997, which worked well with the notebook computer I used in the field at the time (I had been doing reports on a notebook computer in the field since 1994, started out with a Compaq Aero 4 ... first a 4/25 with a B&W display, then a 4/33C with a color display).
After a couple of Mavica-FD cameras (FD stands for 'floppy disk') I went to the CD (compact disk) versions when they came out ... then went to cameras which had the SD-XD-etc cards in them.
Oh well, just some digital camera history from 'back then' ...
Like Robert, who still has his camera, I still have one or two Sony Mavica FD cameras and one or two CD cameras ... the passage of time at a steady rate versus technology at an exponential rate.
03-01-2016, 01:25 PM #12
03-01-2016, 03:16 PM #13
I disagree Jerry. No drifting.
All posted cameras are digital.
I even posted price.
I have never seen a rugged Camera like the Sony HX300 Camera with 50x Optical Zoom.
45 minutes in the rain and it still worked.
A heavy camera but the digital images are superb.
03-01-2016, 07:23 PM #14
03-01-2016, 08:15 PM #15
03-02-2016, 11:44 AM #16
03-02-2016, 12:55 PM #17
03-02-2016, 01:33 PM #18
03-02-2016, 03:01 PM #19
I made my own pole camera.
1. Twenty- five foot painters pole
2. Nikon Cool Pix camera with wi-fi
3. I pad or iphone to view images from camera via wi-fi
03-02-2016, 03:59 PM #20
03-02-2016, 04:05 PM #21
Robert
You can get a mount for the top of the pole at any camera store, electronics store.
I hold the tablet by hand and the app on the ipad for Coolpix allows you to snap stills.
03-03-2016, 07:01 PM #22
I have been using the Fujifilm XP for about 6mths now. It's 50ft water proof...accidentally tried it in shower pan standing water (not 50ft) during a functional drain test...worked great afterwards. The most useful feature is the use of a selfie stick and the fuji app on my android phone to take pics via wifi when looking around objects in attics, over cabinets or around walls/chimneys on roofs. Even if you forget to put in the SD card, it has internal memory...set quality to low. Fits perfectly in side pouch and can be worked/zoomed with one hand.
03-03-2016, 07:12 PM #23
03-03-2016, 08:28 PM #24
It is just a knob that covers the end of the pole. I think at one time it was for something else and they just left it. It does nothing now.
- - - Updated - - -
03-04-2016, 06:38 AM #25
As long as it takes me to look at the pic I just took...it's ready for the next. You can also set it to take two pics...one without flash and one with flash. So when you take the pic, it automatically takes two. I have had the bigger Nikons and used my Samsung phones in the past. I like this camera...battery lasts long enough to get a 3 hr inspection done without worrying.
