Results 1 to 12 of 12
    Mar 2012
    North Central Texas
    Default Crashed and Over
    Crashed my inexpensive SharkSpark drone. R.I.P.
    I need suggestions for a new bird. I've looked until I cannot look further. Too many choices. I would like one that is easy to operate, takes 4K video, GPS, self-returning, auto-hovering, etc. And, most importantly, under $10,000. Please send me your ideas.
    Thanks in advance.
    Texas Inspector
    http://www.texasinspector.com
    Mar 2012
    North Central Texas
    Default Re: Crashed and Over
    Thanks in advance.
    Guess I asked this question on the wrong forum . . .
    Texas Inspector
    Aaron,
    Maybe not many HIs use drones?
    Or maybe it was that "under $10,000" amount that gave those who do the willies?
    https://247wallst.com/consumer-elect...000-on-amazon/
    https://www.amazon.com/DJI-Inspire-B...keywords=drone
    https://www.dji.com/inspire-1-pro-and-raw
    Mar 2012
    North Central Texas
    Aaron,
    JP:
    I edited this several times beginning with a $500 limit and increasing it incrementally up to $10K (like I would ever pay that for something I can crash into the nearest tree) in hopes that the dearth of comments was due to my low ante . . .
    In my area every other HI is hawking drone use. Maybe they are not on this forum. Maybe they have moved on to the next plane, leaving more business for me.
    Best in the New Year
    Aaron
    Texas Inspector
    Orlando, FL
    I saw the first post (at $500) and didn't check back in till now. I had nothing to add to the inquiry at that dollar amount.
    The stability of the Mavic series, combined with overall ease of use, make it a good choice. I don't like that drones all squawk back to the mother ship every time you use one, maybe that can be "modified" or similarly changed.
    The new proposed FAA rule about all drones sending out a "pulse beacon" and sending your flight plan over the open internet before every flight is a bit much.
    Mar 2012
    North Central Texas
    Thanks. I will look at those.
    Texas Inspector
    When one considers that drones are now invading air space previously allowed to other aircraft, piloted aircraft, and while the drone operator is safely on the ground, the drone is not ... and neither are the other aircraft which the drone could have an impact ... advance notice of a flight seems to be the least one would expect of a drone/drone operator.
    Mar 2012
    North Central Texas
    JP
    Agreed. See https://www.faa.gov/uas/commercial_operators/
    Texas Inspector
    Orlando, FL
    Agreed, but, I would expect some sort of alternative, such as a limiting device to keep the thing less than 50 feet or some other reasonable height.
    There are no problems or restrictions with a telescoping camera pole, and most HI's use these things ("drones") as a " remote-camera on a tether".
    See your previous response.
    A very good reason that a tether should not be allowed, same with height above ground limitations - can be modified.
    Maybe if a height above ground limitation which was unalterable, and (a critical vompnonent) an altitude signal relay which verifies height above ground ... a violation results in immediate self-destruction of the drone.
    Mar 2012
    North Central Texas
    [/QUOTE]Maybe if a height above ground limitation which was unalterable, and (a critical vompnonent) an altitude signal relay which verifies height above ground ... a violation results in immediate self-destruction of the drone.[QUOTE]
    JP
    A bit Draconian, but effective. Might be peripheral damage though.
    Texas Inspector
    Aaron,
    Fair enough. I'll revise that to: immediately heads back home (to the controller) and begins to self destruct (no violent explosion, just a simple "falling apart" into small pieces) on the ground at the location of the controller.
