    Default 1997 Edition of the Standard Building Code
    Does anybody have a 1997 Edition of the Standard Building Code that they would be willing to sell, or know where one would be available for purchase?
    Clarksville Home Inspection
    JW Goad
    Default Re: 1997 Edition of the Standard Building Code
    See if the ICC still has some copies, they used to be the SBCCI.
    May (may not) have it in book form, but I'm sure they have it on a CD (originally came on floppies -that's how I go my computer version - also have the books - but I'm keeping them, but I'm sure they have it on CD now).
    Thanks Jerry.
    JW Goad
    What are the differences in the standard building code & the uniform building code?
    JW Goad
    There were four basic model building codes (if I recall correctly):
    The Standard codes - Southern Building Code Congress International (SBCCI) - those were the Standard Building Code, Standard Plumbing Code, Standard Mechanical Code, Standard Fuel Gas Code, Standard Fire Prevention Code (there may have been a few more Standard Codes).
    The National codes - Building Official Code Administrators International (BOCA) - which had similar codes to the Standard codes.
    The Uniform codes - International Conference of Building Officials (ICBO) - which had similar codes to the Standard codes.
    The CABO code - Council of American Building Officials (CABO) - had a One and Two Family Dwelling Unit code, CABO Energy Efficiency code
    They joined together in 1994 to form the International Code Council, combined the codes, and in 2000 came out with the first ICC codes.
    WC Jerry can probably add to and correct the above.
    As to the question "What are the differences in the standard building code & the uniform building code?" ... you would need to compare the two side-by-side for any given section. Some sections will be identical, other sections will not resemble each other at all.
    Charlotte, NC
    John..
    Contact Elaine Smith, Administrative Assistant in Government Relations for the ICC (888.422.7233, ext. 7401, esmith@iccsafe.org). She helped me get a 1997 NC State Building Code, Volume VII - Residential (CABO at the time) about a year ago.
    I had one from a few years back and tossed it when the 2002 NC Residential Code came out (2000 IRC). I regretted it every day thereafter and now I am more of a pack-rat.
    Dave
