Old 05-17-2007, 02:38 PM
David Banks David Banks is offline
Tramex Moisture Encounter Plus
Just purchased Moisture Encounter Plus. Manual is pretty basic. E-mailed the company they say manual is all they offer. Any tips for use of this moisture meter. How to avoid false readings Etc.
Dave
Home inspection
Old 05-17-2007, 02:59 PM
Michael Thomas's Avatar
Re: Tramex Moisture Encounter Plus
1) Metal (for example corner bead) causes inaccurate (elevated) readings.
2) Surface moisture causes inaccurate readings.
That said, still my meter of choice for subsurface readings on dry gypsum board and ceramic tile.
Old 05-17-2007, 04:23 PM
Richard Rushing's Avatar
You'll get alot of false readings on the inside with stucco...
RR
Richard Rushing, HCRI
Duncanville, Tx.
Old 05-17-2007, 05:40 PM
Scott Patterson's Avatar
You need to practice on your own home. It is a great moisture meter, but it does have a learning curve. As with any tool you have to learn it's limitations and attributes.
Scott Patterson
Old 07-17-2007, 09:36 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
What moisture meter type do you use?
Which is best for stucco and EIFS use?
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
  #6 (permalink)
Old 07-18-2007, 02:25 AM
Nick Ostrowski Nick Ostrowski is offline
I'm due for an upgrade and have been looing at the Protimeter Surveymaster. Anybody use one of these?
  #7 (permalink)
Old 07-18-2007, 06:13 AM
For EIFS, you really have one meter that works well enough and that would be the Tramex Wet Wall Detector. If used properly it will help you to zero in on the problem areas. Yes the WWD is expensive, but with a good EIFS inspection it can be paid for in only one job.
For Stucco, not much will work from the exterior because of the wire or metal lath in the wall. I try to tackle stucco from the interior of the home. I use a combination of meters on the interior with the Tramex Moister Encounter being used the most. You really should not probe stucco walls as the probing can cause more damage. When you probe a stucco wall you are putting a hole into the moisture barrier and you do not want to do this!
For probing I use the Delmhorst meters digital and analog. I also use the Protimeter SM with the long probe attachment
Scott Patterson
Home inspection
Similar Threads
MOISTURE DETECTION STICK James Schaefer Tools and Equipment 10 05-09-2007 09:09 PM
Moisture Meter Manual? Tony Escamilla Tools and Equipment 0 05-08-2007 02:58 PM
Is dry rot progressive in absence of moisture? Terry Beck Structural Components: Home Inspection and Commercial Inspection 1 04-24-2007 06:39 AM
vB.Sponsors
Ad Management by RedTyger
