12-17-2007, 02:00 PM
Need a new moisture meter
I lost my moisture meter. It could be in any one of three houses that I had a hard time getting access to.
Anyway, I need a new one.
I'm looking for something reliable, small, and inexpensive. I don't want to spend a ton for something that I am likely to lose again.
Also, who has the best prices?
Thanks in advance.
12-17-2007, 02:25 PM
Re: Need a new moisture meter
Thanks in advance.
Bunches on Ebay!
moisture meter, Industrial Electrical Test, Gardening Plants items on eBay.com
Many inspectors are or have gone out of business during the slowdown.
I like Tramex and Surveymaster the best. They cost the most, but with this type of equipment you get what you pay for. I would not cut corners on a moisture meter. Expect to pay a few hundred dollars for a good one.
12-17-2007, 07:51 PM
Yes. Spend some money. Its tough, but you don't want to skimp on a moisture meter. After I lost some tools and quite a bit of money I got real good at not losing them again.
You wouldn't want your doctor using some low-ball, 2nd-hand equipment in the operating room would you?
I have all three of the major mfrs. I use the Protimeter Surveymaster the most. Its small and convenient.
12-17-2007, 08:27 PM
I bought a couple cheap meters on e-bay. I was looking for something that was small and light and easy to carry in my tool belt and in my pocket in the cralwspace.
I found one for somewhere in the low $20's if I remember right. It even has a hold button to make it easier to photograph the results. I worried about the accuracy and tested it along side my 3 other meters (all larger and heavier) and was OK.
The problem I have had is: 1. my cell phone bumps the on button (They share the same pocket in my tool belt) and I don't notice, so the battery goes down., 2. I have had trouble with the ON button and had to send back two of them for replacement (covered under warranty).
While I own 3 other meters, including one of the $400 units, I think the one from e-bay suits my use very well. Light weight, digital readout and a hold button.
JF
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Moisture Meter Readings |
Jim Dull |
Building Interior: Home Inspection and Commercial Inspection |
10 |
06-01-2007 03:39 AM |
| Moisture Meter Manual? |
Tony Escamilla |
Tools and Equipment |
0 |
05-08-2007 02:58 PM |
Ad Management by
RedTyger
