Old 05-06-2008, 04:31 PM
Ron Bibler Ron Bibler is online now
BEES IN THE WALL
IR camera in my bag at every inspection. this is from todays inspection. I saw one bee fly into the wall of the fire place and then another.
Went inside and took this IR of the interior wall adjacent to the fire place.
I then pointed this condition out to the seller and the buying agent and the seller said that she had a bee guy come 2 weeks ago and get the bees.
The seller then paid me on the spot to mark out the wall areas that needed to be opened to remove the Bees.
Bee man come get em.
The agent saw what the camera can do and how this was a major find for
the buyers. about $ 1,500.00 to get that nest out of that interior wall and
repair and paint. A $ 200.00 Scan is going to be a part of every inspection for this agent from now on.
Best
Ron
Excellence Exterminating and Thermal Imaging
Old 05-06-2008, 04:35 PM
Fritz Kelly Fritz Kelly is offline
Re: BEES IN THE WALL
Thats way cool! Sounds like the bee removal business may be better than the home inspection or IR business. I had a client that got a quote for removing bees from a water meter box for $350.
Old 05-06-2008, 04:52 PM
Rick Hurst's Avatar
We have beekeepers here in N. Texas that will "rob" a honeybee nest for no charge at all.
I used to smoke them out of a hive but we had a 250. minimum and most did not want to pay for the service.
Once the bees are removed though, that is not the end of the problem. All that honey or nest if not removed turns to sugar and then quess what?
Every species of ant known to man shows up at that house for dinner.
Pharoah ants are the worst to have to deal with in that situation, but even carpenter ants can move in and become an issue.
So tell your client to figure in an extra 500. a year for the Pest Control Co. once they move in.
Rick
Old 05-06-2008, 05:17 PM
Rick Hurst's Avatar
Ron,
Sorry dude, I forgot your in the PC business also.
Here is a pic I took of some bees some time ago.
Old 05-06-2008, 05:52 PM
James Duffin James Duffin is offline
Bee's are like bat's....they come back to the same place to roost. I have a beekeeper friend who will come get the bee's at no charge but does not fix the damage. Varmint damage is not hard to find if you know what to look for. A bee hive is not hard to find.
And not to bee negative....but unless the Realtor is going to pay the extra 200 from their commission I doubt the client is willing to pay for an extra service that will most likely produce no results. IMHO...of course.
  #6 (permalink)
Old 05-06-2008, 05:53 PM
Hey rick. looks like you where up close to that nest.
Rick
I don't do bees and fles and orther things like that.
I do Building inspection for Termites, Fungus and damage. in Calif A structural pest control building inspection covers just about everthing but the Electrical, Heating/Air. unless we have termite/fungus damage under a heating unit or an Electrical system. then they into play. Under my lic. I can Inspect the systems and contract to make the correction i find and issue a clerance on the property. unlike H.I. in Calif they can only inspect not repair or fix things they find. The Calif state contractors licesing board and the structural pest control board was one in the same back in 1960. then they did a split.
Best
Ron
  #7 (permalink)
Old 05-09-2008, 06:19 PM
M. Waller M. Waller is offline
James is correct on the coming back issue.
Typically you need to have someone remove the bees and then someone to do the repair work and cap off the place where they entered or there is a high chance they will be back.
Home inspection
Similar Threads
Cracks in wall mathew stouffer Structural Components: Home Inspection and Commercial Inspection 6 05-11-2008 07:12 AM
Single Wall vs. Double wall vent pipe Jonathan Clevenger Plumbing System: Home Inspection and Commercial Inspection 2 03-08-2008 10:10 AM
Fire wall or no fire wall. william siegel Attic Areas: Home Inspection and Commercial Inspection 6 10-23-2007 04:55 PM
SIngle wall? Clay E White Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 07-26-2007 06:34 PM
SIngle wall? Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 1 07-02-2007 11:04 PM
vB.Sponsors
Ad Management by RedTyger
