Hi,
I have an older house, 1955, and none of the wiring is grounded. However, there are new GFCI outlets near all of the sinks and water supplies.
Questions:
Are GFCI outlets at water sources sufficient or do the outlets also have to be grounded to be up to code?
If they are not grounded, will the GFCI work correctly?
Will FHA finance a house that is not grounded but does have the GFCI outlets at water sources?
Thank you in advance.
