Old 04-29-2008, 05:02 AM
Kirk Hersee Kirk Hersee is offline
AC Placement
Does this AC unit have enough or proper clearance? I included it in my report but it wasn't cited for the re-inspection. It may be due to the room isn't in use at this time. But, nonetheless, is it proper? I didn't measure for clearance, although, I think you can see in the photo, there is none. Kirk
Home inspection
Old 04-29-2008, 05:33 AM
Rick Hurst's Avatar
Re: AC Placement
Man, thats a depressing site.
That condensing unit has no clearances as needed. It should be a minimum of 3" off grade. Looks as if the soil is in contact with the unit.
The preachers pulpit needs to be removed over the top of the unit to assure proper ventilation.
But by the looks and age of that condensing unit, the HVAC contractor should correct all of those items when he replaces it anyway.
Snow and its nearly May. How do youse guys handle that? I'd have to pack it up and move south.
Old 04-29-2008, 05:41 AM
John Arnold John Arnold is offline
Re: AC Placement
Isn't that a window unit?
Old 04-29-2008, 05:53 AM
Re: AC Placement
Rick, I think I had done that one in February. The snow's gone now. John, yes, that is a window unit.
Old 04-29-2008, 06:33 AM
Re: AC Placement
Window unit or though-wall unit? Makes a difference.
Windows are only about 1/8" thick, walls are about 10" thick.
Installing a window unit in a wall will block half or more of the vents, which looks like was done there.
Clearance? To ground? No, it should not rest on, nor be partially buried in, the ground. I've never seen a window or through-wall unit (or even a regular condenser unit) rated for 'direct burial'.
  #6 (permalink)
Old 04-29-2008, 06:40 AM
Re: AC Placement
Quote:
...I've never seen a window or through-wall unit (or even a regular condenser unit) rated for 'direct burial'.
Although, this one appears to be an excellent candidate for COMPLETE burial!
Home inspection
Similar Threads
Electric baseboard placement Reis Pearson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 3 04-09-2008 06:52 PM
Smoke alarm placement dan orourke Electrical Systems: Home Inspection and Commercial Inspection 16 09-11-2007 08:36 AM
Search ranking & placement. Kevin VanderWarf General Chit Chat: Home Inspectors & Commercial Inspectors 7 08-05-2007 02:03 AM
WH Vent Firestop collar placement John Stephenson Plumbing System: Home Inspection and Commercial Inspection 6 06-09-2007 09:47 PM
Smoke alarm placement dan orourke Electrical Systems: Home Inspection and Commercial Inspection 5 05-07-2007 05:26 PM
vB.Sponsors
Ad Management by RedTyger
