    Apr 2021
    CA
    Default what material is required for a conduit for wiring out of electrical panel
    Is a rigid metal material required?
    Is it legal to use plastic like the picture? what code regulates it? Thank you.
    Capistrano Beach, CA
    Default
    Welcome to InspectionNews!
    Thank you for registering and posting your message here.
    If there is anything I can help you with please let me know.
    InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: what material is required for a conduit for wiring out of electrical panel
    Tiny picture. I can't see what the material is.
    Typically, when PVC conduit is used outside, schedule 80 is required.
    California enforces the California Electric Code, which is based on the National Electric Code. You can view it here:
    https://www.dgs.ca.gov/BSC/Codes
    However, some municipalities, such as L.A. have additional local requirements.
    Orlando, FL
    Agreed, although it looks like Liquid-Tight or some sort of flexible whip.
    Apr 2021
    CA
    [QUOTE=Gunnar Alquist;287769]Tiny picture. I can't see what the material i
